(Not very) Safety bracket for tailgate
sfretwell
Steven
Roseville. CA
2024 Maverick Lariat Hybrid
The safety bracket on the passenger side of the tailgate. This is a diagram showing it, got it from another thread. I could probably bend it back into shape by hand but I might end up breaking it entirely.
So I managed to bend mine way out of whack, and need to replace it. Doesn't strike me as all that safe. Though as long as I'm working on the tailgate I'll probably add dampers too. Anyone know where to buy the bracket from though? Or am I going to have to call the Ford dealer? I can't find it in any of my aftermarket catalogs.
Maybe ?
Could that be the bracket contained in #4 ??
Ford Maverick (Not very) Safety bracket for tailgate 20241015_083603
Ford Maverick (Not very) Safety bracket for tailgate 20241015_083001
Good Luck
That is not what this bracket is. You're describing the optional tailgate lock.
It is the safety bracket that prevents the tailgate from lifting out. It has to be removed to install the anti theft tailgate lock. The safety bracket can be replaced/ augmented with the anti theft tailgate lock or with a hose clamp. The anti theft tailgate lock is just harder and takes longer to remove than the safety bracket which is solely there to prevent tailgate from bouncing out. Either or both can be used. Depending on bend in safety bracket it might be straightened enough to work.
fossil
ernie
ohio
I suppose if the tailgate was cabled in the "mid" position and unloaded you could bounce it out of the socket with a rough ride. Hammer it out the best you can til it can be replaced, you're not going to destroy it. They generally don't make stamped steel parts from brittle metal.
npaladin2000
npaladin2000
NY
2022 Maverick XLT Hybrid, 2025 Maverick Lariat Hybrid
I may just leave it off entirely. Definitely leaving it off for now. But it's...bent.
Ford Maverick (Not very) Safety bracket for tailgate 20241015_132759
Don806
Don
SE Ohio
this piece has to be removed to install the Mcgard tailgate lock. I'm sure there is someone on here who has removed theirs and still has it somewhere that you can get cheaper than buying from the dealership (maybe since postage/shipping is so high priced these days). send me a message, mine was under the backseat of the truck. I'll find out how much to mail it.
Ford Maverick (Not very) Safety bracket for tailgate 1729015291315-y5
Don806
Don
SE Ohio
the number on it does no good, but pretty sure this is it:
Ford Maverick (Not very) Safety bracket for tailgate 1729016317363-rj
dealer should be able to get it for you for less than I could mail mine.
commadorebob
You can likely bend it back into a useable bracket; if not you have only lost a little time.
Agree. A hammer and a pair of pliers may save you some money. Worst case, you end up exactly where you are now: needing a new one.
Ponyprez
Kevin
Southern New Mexico
1965 Mustang 2+2, 2023 Mach E, 1990 Mustang 7UP Convertible, 2023 Maverick,
Isn't that the theft deterrent bracket that you have to remove to remove the tailgate? How did it get bent? I got my tailgate lowering strut and braket from e-bay and it lowers the tailgate softly with no resistance when raising.
OP answered in post #15
It had nothing to do with lowering a tailgate or a tailgate damper.
rclee
Rob
Dayton Ohio
Ball Peen hammer + Vice + patience is all you need to fix your problem :)
