Grabber Rick
Rick
Sarver Pa.
07 Focus wagon 06 Silverado 4x4
My solution for the flap gap on the left rear mudflap. I bought a 12x12 piece of kydex on Amazon, .080 thick. Link: https://www.amazon.com/Plastics-2000-KYDEX-Sheet-0-080/dp/B077S64M76/ref=sr_1_3?crid=380J4RA9SAKZZ&dib=eyJ2IjoiMSJ9.HyHC5vA9nuVrHTkgUQChz153XKZv9BcRbWIk7Mho9c4NNCNenJvqrC9e56kT86cIG3U_uQNg2V5cJlg3llkHT_W2EFF2X-Os1ToUvBPpDesZKbRvIvDGvjcnnX-gLOf2ySbKpPxOqg68XHnuzu7xOoPjAWXJLdKAQNtOukc_sed87Aw5Wt7WIq-ELWNab0r9m5KaZiFodpiv_FlGelkHJtXFkr3uyCb_m_frJ09njY4.Qi2DqYiyheTUjKDIG-wQlMvCbjnc8mfOk_aoCsxM1UY&dib_tag=se&keywords=12x12+piece+of+Kydex&qid=1719768191&sprefix=12x12+piece+of+kydex,aps,129&sr=8-3
Had to cut about 1 inch off the side . Removed one upper plastic clip, and slid the piece of kydex up so it looks like the mirror image of the right side area behind the right flap.
Used a stainless 1/4 inch bolt and washers and a self locking nut to hold the top, and drilled 2 holes in the bottom and held with the extra clips from the mabett flap install.
I hope these pics show up, my computer skills are lacking. I got the install done quicker than trying to post this thread.:sadface:
I put Maybetts on my truck. Passenger front came loose. Bottom puch pin clip was gone and the middle one had a broken clip. Half on one side. Top was still in but it was swinging side to side and flapping towards the tire. Thinking about using plastic rivets or licence plate inserts so I can thread small stainless screws in. Seems flimsy with just push clips.
Builder
Kevin
Connecticut
2023 Ford Maverick Lariat
Why can’t Mabett simply modify the driver side rear design mudflap to eliminate any gap up to the wheel well? If they offered that one modified mudflap to current Mabett mudflap customers, I would buy that one replacement mudflap in a second! I think others would also, to protect the open void behind the driver side wheel well. Mabett …. Are you listening ….???
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Jeff W8
Western Washington
2023 Ford Maverick Lariat Hybrid
I just did this - thanks for the inspiration!
Ford Maverick My mudflap gap fix using kydex thermoplastic sheet mav-wheel-well-gap-cover-1
Ford Maverick My mudflap gap fix using kydex thermoplastic sheet mav-wheel-well-gap-cover-2
This is what I bought on Amazon:
https://a.co/d/0f7IaCCz
I attached it using a bolt up high, and a couple of screws down low with lock washers.
If I had to do it again, I would use an 8x12 piece of plastic that is 1/16" thick instead, like this:
https://a.co/d/04H5VpkR
And I started with the screws on the lower part, but I realize it would have been a lot easier to start with the upper part - that was a bit of a pain :)
I'm glad I did it - that big gap is no longer jumping out at me every time I walk by it.
Thanks for the pointers, @mepot101!
FloodingdowninTX
Fusion
There's at least 1 or 2 threads about their mudflaps. They may still be sending replacement clips if asked but it takes a long time to arrive. Hope this helps.
