Mdmac
Kansas
2023 Maverick XLT
Hello, I will look into the lenses because I'm OCD also I just kinda gave up. Yes they flash with the
Sadly I'm a perfectionist. If there's something I can do to make it look a little nicer it drives me nuts until I get it looking just right.
These also flash when you unlock/lock the doors, with the rest of the exterior lights.
Yours look good as well you just need the colored lenses to hide the LED for a more finished look.
https://www.ebay.com/itm/404634914125?var=674628691131
Taillights, marker lights when you lock/unlock the truck.. I will check into it.
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
I really want to smash this and the Mabett setup into one. Maybe get three LEDs into that "deadspace" in the middle.
Jims Maverick
On Line
maverick
Finally got around to doing this the right way. I tried the Mabbet revised version with the smoked lenses, and wasn't a huge fan they just look too plain and stick out too far on the fender compared to OEM.
So I used my own OEM XLT fender inserts and painted them to match. Now the only Chrome left is the headlights and tail lights bowls. I used a small 5/8" round amber LED for the blinker and a frosted lens cover. I ordered the turn signal adapter harness from custom Auto works store for $50, way overpriced but it was so much easier than doing it myself for the harness.
I got the LEDs as well as the wiring to extend to the OEM blinker from super bright LEDs.com here in St Louis Missouri. I already had the paint so that was no extra cost all in all the mod probably cost me about 85.00, Plus my time for painting. If anybody needs part numbers for LEDs are the blinker harness adapter let me know.
These are much brighter than the Mabetts with their smoked lens and easier to see in the daylight as well. Really happy with the way they turned out.
Amber led. https://www.superbrightleds.com/bolt-beam-12mm-led-light-55-lumens
Lens covers. https://www.ebay.com/itm/404634914125?_trkparms=amclksrc=ITM&aid=777008&algo=PERSONAL.TOPIC&ao=1&asc=20240130164827&meid=07ab17de7d264e1583bc02d13aa8d194&pid=101959&rk=1&rkt=1&itm=404634914125&pmt=1&noa=1&pg=4375194&algv=RecentlyViewedItemsV2WithMLRPboosterAndUpdatedFeatures_BP&_trksid=p4375194.c101959.m146925&_trkparms=parentrq:5e72d4831950a5ad628c44a0fffff9b6|pageci:79220530-f88b-11ef-924d-7ac34d74e1b6|iid:1|vlpname:vlp_homepage
Turn signal adapter harness. https://customautoworksstore.com/product/2022-24-ford-maverick-side-marker-plug/
I installed my MA bets and they work great! The chaser light feature is cool!
The Maverick has been sending lpw battery messages, and Ford emailed me unsolucited that I should have the dealer perform a free battery test. I did that at my oul change, and they noted that my after market lights (?) could be the problem? Except I was getting warnings well before I put the lights in. And, they only come on when all the lights turn on, so, really?? I've done enough electrical work in homes and cars to know a brush off when I hear one. A bit insulted the dealership thinks it customers are that gullible...
Rentech54
Marcel
Calgary Alberta Canada
2023 Maverick XLT AWD
I ordered my inserts from Spotify last year from GadCAD 3D.com
I bought some LED inserts also
BUT my daughter bought me a set of Mabetts side marker so I have these as a spare.
Ford Maverick My fender indent blinker light / turn signal custom DIY mod. IMG20250310115932
Ford Maverick My fender indent blinker light / turn signal custom DIY mod. IMG20250310115925
Edd
Edward
Lehigh Valley, Pa
2012 Hyundai, Ford Maverick Area 51 AWD
Nice job. Been thinking about that mod for my 22 Mav.
Being an ex biker I can see the importance. Wish Ford would
offer a blinker on the side mirrors also. Thanks for the post.
Toddman45
Toddman45
St. Louis, MO
Agreed there's many things Ford could offer in the Maverick that they don't or no longer due such as blinkers in the mireorcaps, power passenger seat, door sail installed keyless entry keypad, full led taillights, rear defroster on the back glass.
Cvinnedge
Chuck
Virginia
2025 Ford Maverick XLT AWD Hybird
This is great. Wish they were package with the lights and plug and play wiring and I would be a customer.
Mdmac
Kansas
2023 Maverick XLT
I made my own and it was really easy. I ordered a set of Amber Lenses from ETSY and some small LSD Lights from Amazon then just wired them in. They flash when locking/ unlocking the truck and also are a turn signal indicator. I did not like the other ones you can purchase. Best of luck 🤞 A short video
Ford Maverick My fender indent blinker light / turn signal custom DIY mod. IMG20260723100039
Cvinnedge
Chuck
Virginia
That is what I want. Simple and looks great. What LSD lights did you buy and is there a wiring harness that plugs in or did you have to splice the wires?
Mdmac
Kansas
2023 Maverick XLT
Hello, sorry I meant LED Lights that I ordered from Amazon. I can look for the Item/ part number and send it to you if you want?
Mdmac
Kansas
2023 Maverick XLT
Will get it to you as soon as possible and I will take a picture as well
Cvinnedge
Chuck
Virginia
Thank you. I appreciate it.
