Monitoring Hybrid Battery State-Of-Charge
GPSMan
Many
Not very hot. 145 to 165. But I get it up to full operating temperature at least once a week. 🤷🏻‍♂️
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
It is good that you get the oil up to full operating temp at least once a week. But I wonder if the accumulated moisture between those full op runs is a detriment to ICE longevity? I know it would bug me. How often do you give it the beans and really let her rip?
GPSMan
Many
Well, driving gently at first I was at 10,000+ for the computed Oil Change Interval. Then I towed over the mountains for a couple of tanks back in October and OCI is now set to run for 9000 miles (total). So 1000 miles drive took 2000 miles off the oil, so the "smart" meter knows I did towing or ran at higher RPM's. I wonder if the OCI counts total RPM's? Like change your oil every 20,000,000 revs. With lots of EV miles, you'll get longer OCI. 🤷🏻‍♂️
GPSMan
Many
No I see the point. Avoidance might be achievable in Michigan but I don't know how San Francisco guy avoids other drivers while in San Francisco.
What are you talking about???
Avoiding other drivers?!! Around San Francisco?!! It's super congested! I'm bumper to bumper 95% of the time!
Slower you go, the higher your MPG!
Tonight, longer trip, super high MPG:
Ford Maverick Monitoring Hybrid Battery State-Of-Charge E54618CD-FEB1-40C8-A1BA-E44A3EC43215
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
GPSMan,
What are the codes you use for traction battery temp?
DesertSweat
Arizona
Ford Maverick Lariat, Honda HR-V 6spd
I have 5400 miles now, mpg showing 52.8 . Worst tank full was 39.9 so far , cold weather and some interstate.
I've found the truck overestimates by 10%. Use fuelly to get real averages.
Uncle Ed
Georgia
1968 Camaro, 2017 Toyota Highlander, 2024 Maverick hybrid
The 39.9 mpg was figured by hand, I found each h tank full was over estimated by about 2 mpg by computer, so probably subtract 2 mpg from the 52.9 to be closer to actual.
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
The truck overestimates, but you can use your hand calculated data to calibrate it in engineering mode and make it correct.
Uncle Ed
Georgia
What is this engineering mode you speak of?
jsus
2022 Ford Escape Hybrid AWD
Uncle Ed
Georgia
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
Thanks for sharing the link jsus. I added up fuel used over 10 or so cycles, always using the same pump, and calculated fuel used utilizing the trucks indicated mpg. I divided Maverick gallons by Gas station gallons. For my case I came up with 0.95. The AFE bias is default 1000, I changed it to 0.95 x 1000, or 950.
Ford Maverick Monitoring Hybrid Battery State-Of-Charge imag
CuriousGary
Atlanta
Ford C-Max Hybrid
Normal, varied, busy, congested San Francisco and surrounding Bay Area cites, yes. Quite do-able; repeatedly, and several owners have done this. I'm one of several.
Keep in mind "winter" here is 40°F and summer is about 80°F with low humidity. You can get away without heating or air-conditioning, if you choose, which is 10% to 25% of your gasoline use, depending on severity of weather. My home does not even have an air conditioner.
I understand 800 miles per tank in Indiana or Michigan is just short of impossible. YOU should understand 800 miles is not too difficult in mild weather. I don't live where you live.
Don't be so quick to judge.
Knowing battery SOC is an advantage, a significant advantage in stop n go conditions. In steady state, highway over 55 mph; sure, not much advantage then.
Key to higher MPG in any condition is keeping the Battery SOC lower, so there is always room to charge. If you are not driving in EV much, or at all, you are driving around with a "full" battery. A rarely used "full" battery is nearly useless to you. Literally dead weight. (And at steady high speeds it is dead weight much of the time, but is charged and ready to give you that boost on a hill or that boost of acceleration for passing.)
You could call the hybrids "Battery Boosted" compared to EcoBoost.
Keeping the SoC low to maximize mpg’s is contra-intuitive. It seems to me, the the higher the SoC, the more it is available to push the truck into “electric driving,” shut off the ICE, and therefore get more mpg’s. Perhaps I have misunderstood you. Please explain.
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
I think different situations call for different approaches. I drive hours on the highways. I’ve found once SOC is in the low 60’s, charging current decreases and instant fuel economy increases. As I enter a small town (on state routes) I usually can make it through on battery.
If I was in an urban stop and go, stoplight to stoplight, I’d never get charged, using the battery after accelerating to maintain speed until the next stop probably bouncing 30-40%
Waterick
Richard
Laurens county SC
To get the battery in a low SOC means you have already done just that: driven more on electrics and shut down the ICE.
