- First Name
- Dave
- Sep 19, 2022
- Carthage IN
- Ford F-350 CCSB 6.7
- Engine
- 2.5L Hybrid
Maybe with all the EV’s in CA his maverick is flexing a bit haha
I usually don't have a blue bar that large either. Consider this the maximum, not the typical.Interesting, I’ve never seen the blue battery bar in Mav ever get this big in 1500 miles, is this in a certain driving mode? I wonder if something’s up with mine
I don't have a definitive answer, but my guess is, it's telling you EV mode is possible if demand is low enough. I know what you are referring to. And I don't think I've ever seen it on a cold engine. I'll look for it next couple of drives.
I pretty much confirmed today:I thought it meant combination ice and battery, I'm assuming three possibilities of power , ice, battery, mixture of both. Just my guess , no actual facts.
A "cheaper alternative" has been provided in the solution of Torque Pro and an OBDII reader, which can display on your head unit as an Android Auto app, or on a phone.I also wish there was a cheaper alternative just to get the battery info, but I'm looking into an SGIII as well.
The threshold also starts to reduce over 50 mph and by 55 mph it's pickier/more opaque about what throttle level will transition to EV; sharply dropping to zero throttle often but not always, exacerbated by the readout sometimes taking a second two to update that it's in EV. The bar also may "lie " about being able switch during ICE warmup.I pretty much confirmed today:
Blue bar on the white hybrid bar means "drop throttle (pedal position) to here, and the engine can shut off." It gets longer as charge increases. It won't be present when battery is on the low end, but you can still get EV by dropping throttle to zero (aka take your foot off the pedal).
Torque Pro appears to be a really nice app for Android devices. But I believe the SGIII is significantly less expensive than purchasing an Android phone with a decent-sized screen that can be dedicated to running Torque Pro. The whole point of doing this is to have a "Dedicated" set of gauges so they are always available when we're driving the Maverick.A "cheaper alternative" has been provided in the solution of Torque Pro and an OBDII reader, which can display on your head unit as an Android Auto app, or on a phone.
Let's not move the goal post. You may have said "dedicated", by the person I originally quoted only requested "a cheaper alternative".Torque Pro appears to be a really nice app for Android devices. But I believe the SGIII is significantly less expensive than purchasing an Android phone with a decent-sized screen that can be dedicated to running Torque Pro. The whole point of doing this is to have a "Dedicated" set of gauges so they are always available when we're driving the Maverick.
Now, if I were an Android phone user, and I already had a Bluetooth-enabled ODB2 device, and happened to have an Android device laying around that I could dedicate to running Torque Pro, that might be a way to put that old device to good use.
But I suspect you would still have to power on the Android device each time you start up - lest you either run down your device battery or the truck battery... And that's a non-starter for me - or more accurately for my wife, since she drives "our" truck as well. She's simply not going to remember (or care enough) to ensure the app is up and running, even on a dedicated Android device.
By the way, this isn't an Apple vs Android issue (though Torque Pro appears to only be available on Android), but a matter of "at what point does a dedicated device optimized for the purpose make more sense than a non-dedicated 'app+phone' combination that might be optimal for occasional use?" There seem to be some "dashboard" apps available for the iPhone as well, and I'm not interested in them, either. My phone is way too busy as it is!
The intention wasn't to "move the goalpost," but to point out some of the differences versus using the SGIII.Let's not move the goal post. You may have said "dedicated", by the person I originally quoted only requested "a cheaper alternative".
But by the time you purchase even a $100 phone, some kind of secure mount to hold it where it can be seen while driving, and the Bluetooth ODB2 device, you're within striking distance of the SGIII - a purpose-built, fully supported device that comes with all that. That's all I was trying to point out on the financial side.Old Android phones that have large screens are very common on the used market for cheap, maybe $100 will get you one, maybe even less. They don't need to be powerful flagships to run one app and keep a bluetooth connection established. They don't even need to have active internet connections after downloading the app.
It is certainly less of an issue if you're running it on your "primary" phone that you keep charged all the time, but if you want a dedicated device (as I do), it becomes a bigger deal. You would have to remember to power it on each time you start the vehicle, and off each time you park. I know my wife won't remember to do that - it's not top of mind for her.As far as "but the battery", that's not really a concern because anything electronic added to the truck - ScanGauge or phone - needs a power connection.
You keep moving the goalposts here with irrelevant stuff like "if you're running it on your primary phone" which was not part of the discussion, but you somehow added. You added goalposts for mounts and similar, which would be the same for a ScanGauge as well.The intention wasn't to "move the goalpost," but to point out some of the differences versus using the SGIII.
Yes, you might be able to get most (or even all) of the same information with a potentially less expensive solution, but even if you do have an extra Android device laying around the house, you're still passing up some of the benefits of a dedicated solution. I may have done a poor job of it, but that's what I was trying to point out.
This is NOT an issue with the SGIII, because it is powered through the ODB2 port, so that it powers on/off with the vehicle. No need to tie up one of the USB power plugs or connect to a dedicated power source.
I'm not saying the Android+Torque Pro isn't a good solution for some folks. I'm just saying the price difference isn't as big as you're making it out to be, and comes at the cost of a good bit of convenience and usability.
So why are you moving the goal posts?Let's not move the goal post.
And in all that, said cheap Android phone is still infinitely more flexible and capable.
I'm not moving the goalposts. The original quote was "I also wish there was a cheaper alternative just to get the battery info", and note that cheaper was the only thing specified. Nothing else.So why are you moving the goal posts?
And I 100% disagree. You want a ScanGauge or other DEDICATED OBDII device for semi-permanent installations.
What Jim says is an important fact:
The ScanGauge is "instant on, instant off" just like your dashboard. Automatically on, automatically off, like 1 or 2 seconds of "boot time" and usually no key presses needed.
I am an Apple user, but still, I'd do it no other way. This is ideal for long term or semi-permanent installations.
Very interesting thread. Let’s see some pictures of the Scanguard III mounted in the Maverick. Would like to see if it’s really worth the extra money over the more ideally sized Scandguard II model.
Perhaps a misundersatnding on my part. Clearly when you only mentioned the cost of the Bluetooth ODB2 reader, it should have been obvious that you intended for everyone to also run out and purchase a second Android device to run the app. My bad.You keep moving the goalposts here with irrelevant stuff like "if you're running it on your primary phone" which was not part of the discussion, but you somehow added. You added goalposts for mounts and similar, which would be the same for a ScanGauge as well.
Granted. But you should also grant that the "free" or "really cheap" device you receive may or may not be virus and/or trojan-free, and may or may not expose you (and potentially your vehicle) to higher risk than purchasing from a reputable source that may cost a bit more. At the very least, anyone contemplating this should have some expert help in "cleaning up" the system before using it. Your money - your decision.Also you have to know that the price I threw out for a used phone was a placeholder. They vary from "just come and get it for free so I can be rid of it" to hundreds.
It's called a forum, which by definition is a "discussion group." Discussion is what we do here.You speak of convenience and usability, and again, those were not part of the original request.
(Added emphasis is mine.)<<snip>>
Before I spend $270on a new ScanGuage, I am hoping there is a way to make this work with my old ScanGauge II. I am well versed at using the X-Codes feature on various different vehicles and have had the ScanGauge II in all my vehicles for around 8 years. It looks like the ScanGauge III has an automatic programming mode that allows this data to be viewed - I am curious if GPSMan would be able to view and share the programming codes.
<<snip>>
I am also aware of the ability to use a bluetooth OBDII reader with android and Torque Pro app. I actually have this on an old phone of mine, but don't like it as a permanent solution because it is another thing to have to turn on when you get in the car to drive.
<<snip>>
Nope - I just pointed out that with the SGIII, you do NOT have to do that for yourself, which may or may not incur additional cost for you. It is less convenient, and especially so if you don't have the "know-how" to fabricate that "tap" for yourself.As far as power, I already specifically referenced tapping power from the same OBDII port that data was being gathered from - just like the ScanGauge - but you ignored that.
