Mold Mildew odor
Farming4Life
Cyndi
NC
2022 Ford Maverick XLT
In October 2023, we took our 2022 Ford Maverick to a local Ford dealership for a front airbag recall. Their technician (supposedly) replaced the front airbags during this time. However, after we picked up our Maverick and we got home we noticed a deep scratch across the top of the dash and the tool from the technician in the console. We contacted the dealership about this scratch, told them he would bring the truck by there for them to observe. The individual seen the damage and said they would need to order a new dash and schedule the replacement. This didn’t happen until after the first of the 2024 year.
Our Maverick was taken to the dealership in January 2024 for this repair. After a couple of weeks, the dealership contacted my husband with an update. Upon the completion of installing the dash, the technician scratched the outside of the passenger door causing yet another delay. The Maverick was then taken to their body shop (on premises) to repair the scratch and repaint the door.
After all this, we finally got our Maverick back from the dealership after almost four weeks. Within a week of having our Maverick back, we started smelling a very foul odor in the truck. As time went on, this horrific odor got stronger. This smell made my throat and nose burn and was nauseous while riding in the truck even with the windows down.
We went back to the dealership to meet with the owner about this odor. We didn’t have this odor in the truck until after the front air bags were replaced.
They have strived to resolve this odor issue to no avail. They removed the seats, carpet, and dash to locate the problem. They discovered a place at the bottom of the windshield that had not been sealed from the manufacturing production department.
They discovered black mold in the insulation behind the dash near the firewall and under the carpet. They have discussed this with Ford Motor Company on how to handle this problem.
This is a problem with the manufacturing production at Ford Motor Company and they should be held liable in correcting this problem. Ford Motor Company should correct this problem by replacing our Maverick with a new Maverick, even trade.
This is no fault of ours, but all of Ford Motor Company.
As Ford Motor Company advertises to support “quality customer service”, therefore they should make this right to our satisfaction.
Tim d
Alpena
Ram
This is a known issue observed on this forum for almost 2 years. Apparently a cowl seal on some mavericks was not installed correctly. I have checked our passenger side carpet a few times since getting our maverick over a year ago and no moisture so I assume mine was installed correctly. Hope they get yours taken care of,you have been thru a lot!
Farming4Life
Cyndi
NC
This smell happened after they replaced top of dash. Ford needs to make it right ✅️.
This is all on Ford.
We have enjoyed our Maverick.
Elduchey
Los Angeles
2025 Hybrid
It could be the cowl but in my case it was the rear window. It took me two years and four trips to different dealers to figure it out. They had to replace the entire rear glass and re-seal everything but apparently it's tight as a drum now.
They also replaced all of the carpet and padding all under warranty.
Carlitos_92
Farming4Life
Cyndi
NC
Ford should make good on their trucks. This is terrible customer service. I will not drive in a vehicle smelling of mold and risk my health over the negligence of Ford Motor Company.
This is absurd and pathetic on Ford.
Jersixmlp
Alex
2021 Ford F-150 Lariat
I had a similar situation at my place, and getting proper testing made a big difference. I ended up using rcrmold.com because they handled both the inspection and the cleanup, and the lab reports helped me figure out the real source of the problem. The whole process felt straightforward, and the air in my home finally stopped triggering my allergies.
