Missing Splash Guard Above Rear Left Tire? exposed Wires?
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
Muslogy, Mabett, RealTruck — a project development idea.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Mine has been fine, since April 2023. Sure it "could/should" be "better", but Ford is selling a "cheap" truck!! :)
12beach
Massachusetts
2024 Hybrid XLT
Well they will indeed be a problem if you live in the north.
Those will get ice built up and they will get ripped off. If you never encounter that. They should be fine. I would personally get under it and try to secure them better.
Thanks I do live up north so I think this is going to be a problem. I will try to zip tie and tape them.
Waterick
Laurens county SC
I would also fabricate or install a shield to prevent winter slush/brine from being thrown up into tail light area causing premature rusting. Search threads here on the subject. Just do a search on "left rear wheel well gap" for starters.
710-oil-614
Cal
2025 Hybrid AWD Lariat
I was appalled when I rust pro'd my Tremor and the underside looked like spaghetti full of electrical connections.
Definitely will not stand the test of time.
jimcebula
Pittsburgh
Lariat Lux
Not sure about the wiring but my weathertech mud flaps cover that gap on left rear.
  • Like
Reactions: uga
ianjay
Ian
Toronto, Ontario, Canada
2024 Maverick Lariat Hybrid , 2008 Ford Ranger
I guess this is your first pickup. I've owned pickups for decades and open areas behind the wheels are the way ALL pickups have been built.
I agree it looks a little unfinished and is a definite place for road crap to build up but Ford has been doing pickups like this for ever. You can make up a filler panel but my advice is to make it removeable so you can inspect it periodically.
Dribbles of water seeping between tailights and outer fenders is not a new thing. I use an oil based rust proofing system which coats all exposed areas and the wiring and is done yearly. My 2008 Ranger has exposed areas like this on BOTH sides but I haven't had wiring issues. My Maverick is now getting the yearly oil treatment.
12beach
Massachusetts
2024 Hybrid XLT
Thank you! Yes it is my first truck. I will do that and appreciate your help!
In your experience, is it normal / ok to have those exposed colored wires out? I plan on covering them with tape, but I just didn’t know if it is normal for them to be exposed at the connections.
Johnkn
MD
Crawl up under any modern pickup and you’ll see dozens of exposed wires for lighting, sensors, etc..
Your truck will be fine.
Good luck
Who Installed your hitch??
BlueMav43
Roger
NE FLA
2023 Ridgeline RTLE, 2018 Tahoe LS
Snox801
Levi
Spring Lake Michigan
Ye sir you spend a bit of time supporting them better you should be fine. The wires themself being open is no issue. But I would recommend like stated above. Coat them.
I’ve used amsoil had metal protector for years with good luck. Also like fluid film and the newer on blaster. All should keep corrosion away for a few years longer.
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
Mud flaps would help but there is still a gap that I had to cover using sheet metal, aluminum is easy to work with, I used a brass kick panel because I had it, even stiff plastic like a campaign sign would work. Picture is dark square but it should give you an idea. I don't post on YouTube.
Ford Maverick Missing Splash Guard Above Rear Left Tire? exposed Wires? IMG20230130105504
