Maverick on the beach?
Xbert
New York
2026 maverick XLT AWD
Got a 26 xlt awd eco. Would like to take it on the beach. Anyone have any experience/ thoughts on this. Thanks
Cancunbadlands
Cancun
Cancun
Includes a dedicated "Sand" mode. This adjusts the throttle mapping to be more linear and changes the transmission shift points to keep the 2.0L EcoBoost in its power band (250 hp and 277 lb-ft of torque), preventing the truck from bogging down in deep patches.
bgn
WA
Have a way to get unstuck if you do get stuck.
That usually requires a more capable vehicle around you and a way to yank you out, so make sure you have a hitch/recovery point.
matmondro
Mathieu
Vassar, MI
JasonDroninAround
Jason
Hanford, CA, USA
www.youtube.com
2025 Ford Maverick Tremor
Air down to at least 20 psi. For your first time, go to a place that has other people there to help you get unstuck, if it happens. I don't really think driving mode is as important as turning traction control off. You do not want to slow down or stop in any soft areas. If you have traction control on and the wheels start spinning, the TC will cut the throttle and slow you down even more. You want to go faster, not slower, even if it means spinning the tires. If you enjoy the sand and want to play more, think about buying your own recovery rope. If you are stuck, a stranger comes along, and neither one of you has a rope, it's a bummer.
Cancunbadlands
Cancun
Cancun
Steve Wolf
Steve, W8IZ
North Olmsted, Ohio
2024 Maverick XLT, flat towing, with ham antennas
The term “the beach” is meaningless. Every beach is different. Some have sand like concrete. Some have cottony sand that even the best four-wheel-drive vehicles struggle to cross.
For example, on the Outer Banks of North Carolina, your Mav wouldn’t have a chance.
On Galveston Island, Texas, your Mav will do fine. As will a forty-foot motorhome towing an F-250.
No, DON’T TAKE IT ON THE OUTER BANKS.
Yes, take it to Galveston Island, Texas.
Old Young Man
Patrick
Ormond Beach
2024 Maverick Lariat Tremor
It definitely depends on the beach surface. Some beaches in Daytona don’t require 4x4 and it changes due to weather and tide.
MaverickDragon
Grand Canyon, AZ
Suggestions?
If it's a beach at the ocean, don't go there.
Salt air and water is a great way to give your truck cancer, aka rust.
If you do go near / on salt water, that's a virtual guarantee unless you wash the bejebers off of the undercarriage.
Steve Wolf
Steve, W8IZ
North Olmsted, Ohio
"Salt water will ruin your truck!!!" Back when Grandpa was driving a Chevy Vega, that was pretty much the case. Back in ‘71, those Chevys would disintegrate if left in view of a salt shaker.
On the Outer Banks, I was four feet above sea level. On Galveston Island, I am 6.3 feet above sea level. In either location, the idea that you aren’t going to drive in salt water is silly. You will. Sometimes quite nimbly because you have to get where you need to go, even though there is a lot of water. Then there’s the salt fog. You have to wipe down the windows in the morning because of all the salt left on them.
In Northeast Ohio, we slather the roads with so much salt that even a black truck turns a grayish white.
No. The truck doesn’t melt like the Wicked Witch. It doesn’t combust due to electrical problems.
I use my truck. And like the guy fishing from the back of his truck in what looks like southern Texas, my truck sees salt. It really isn’t that big of a deal. I’ll run the thing into the ground before any minor problem the salt causes.
MaverickDragon
Grand Canyon, AZ
Anything made of steel can and will rust, and salt is a great enabler of that.
Maverick hoods won't because they are aluminum, but the steel parts - different story.
Maybe chemical reactions are different in your universe, but I doubt it.
Why do you think cars in the snow belt with salted roads rot before their engines wear out and car bodies out in the desert last for decades... It's the salt, or lack of it.
