Maverick on the beach?
Mavster Mechanic
Hybrid
Anything made of steel can and will rust, and salt is a great enabler of that.
Maverick hoods won't because they are aluminum, but the steel parts - different story.
Maybe chemical reactions are different in your universe, but I doubt it.
Why do you think cars in the snow belt with salted roads rot before their engines wear out and car bodies out in the desert last for decades... It's the salt, or lack of it.
Technically salt in water and that salt-water solution needs to have oxygen too. But this group hates to be technical. :crackup:
No oxygen, no rust.
No water, no rust.
Of coarse in real life the three are found together frequently.
Timothyd
The term “the beach” is meaningless. Every beach is different. Some have sand like concrete. Some have cottony sand that even the best four-wheel-drive vehicles struggle to cross.
For example, on the Outer Banks of North Carolina, your Mav wouldn’t have a chance.
On Galveston Island, Texas, your Mav will do fine. As will a forty-foot motorhome towing an F-250.
No, DON’T TAKE IT ON THE OUTER BANKS.
Yes, take it to Galveston Island, Texas.
I get to the Ozarks and there's a lot of gravel. If it's fresh (from recent flooding) it's loose and use very gentle throttle.
Ryom
PA
2025 Lariat 4K BAP Eruption Green
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
"Salt water will ruin your truck!!!" Back when Grandpa was driving a Chevy Vega, that was pretty much the case. Back in ‘71, those Chevys would disintegrate if left in view of a salt shaker.
On the Outer Banks, I was four feet above sea level. On Galveston Island, I am 6.3 feet above sea level. In either location, the idea that you aren’t going to drive in salt water is silly. You will. Sometimes quite nimbly because you have to get where you need to go, even though there is a lot of water. Then there’s the salt fog. You have to wipe down the windows in the morning because of all the salt left on them.
In Northeast Ohio, we slather the roads with so much salt that even a black truck turns a grayish white.
No. The truck doesn’t melt like the Wicked Witch. It doesn’t combust due to electrical problems.
I use my truck. And like the guy fishing from the back of his truck in what looks like southern Texas, my truck sees salt. It really isn’t that big of a deal. I’ll run the thing into the ground before any minor problem the salt causes.
Yes sometimes the roads Here in Northeast,Ohio are white and it's not snow it's salt!!
MaverickDragon
Grand Canyon, AZ
Believe it or not the mountain areas of Arizona get snow and roads get salt.
Down in the south the only salt the locals deal with is in a shaker.
I lived very near the beach in SoCal and right next to a salt water canal, and my motorcycle didn't like it.
Anything metal that wasn't painted, waxed or sealed would suffer as well.
The beach is a perfect blend of high humidity, salt and oxygen.
Ferrous metals don't fare well.
