Maverick Hybrid brake system grabbing and/or rough engagement at low speeds
Randaddio
Randall
Irvington NY
'22 Ford Maverick
Had maverick at dealership today for graping brakes.Last time in, install previous tsb and it didn't work. So they called ford and they told dealership to install electronic brake booster,which they ordered. So then tsb 23-2060 comes out. I set up another appointment and they install that tsb and that doesn't work.Told me they will call when brake booster comes in. I love it when a plan comes together.
[/QUOTE]
Randaddio
Randall
Irvington NY
'22 Ford Maverick
That's not very encouraging. When if ever does an issue like this qualify for pursuing legal action under the lemon law, or does Ford simply keep issuing TSB's to dodge that bullet?
bill67
William
Pa
Toyota
I'm hoping they find the problem. I don't know if the brake booster will solve the problem.But that's not a tsb.
DryHeat
DryHeat
Arizona
Jeep Patriot
I just had the grabby brake fix (TSB 23-2060) done last week. So far, no more brake grabs...
BUT...
The status report says my rear brake pads were down to 5 (mm, I think, doesn't say), while the front pads are only down to 8. They said I will need to replace the rear ones later this year.
This seems odd because I am very, very gentle on the brakes. I try to get as much regeneration as I can and to limit the amount of braking done by the regular braking system. And I very seldom carry much of a load -- usually just one passenger and a bicycle.
I am wondering if the grabby brake issue has something to do with it.
Has anyone else seen this?
Sometimes not unusual for hybrids to wear out the brake pads faster. The regenerative braking only works for the front wheels, after all, so to provide balanced braking forces the rear mechanical brakes still may be applied.
Randaddio
Randall
Irvington NY
'22 Ford Maverick
BUT...
Yes, TSB 23-2060 fixed my grabby brakes, and I too had unusual wear on the rear rotors only with only 12.5K miles. The paperwork says they lightly sanded them down from 10.9 mm to 10.7, still in spec.
I’m relieved they got the grabby brakes issue resolved and now I’ll just have to keep an eye on the rotors, a minor inconvenience compared to the brakes grabbing.
Anyway, I’m glad that’s over with.
Randall
DryHeat
DryHeat
Arizona
Jeep Patriot
Thanks, that makes sense. Assuming you mean it's "not unusual for hybrids to wear out the REAR brake pads faster."
Here's an article that gives a more detailed explanation of why that is. Basically the same as what you said. And, on the good side, it also says that in hybrids generally wear out the front brake pads slower than pure ICE vehicles.
GPSMan
Many
I had a 2005 Escape Hybrid until 2019.
This never happened.
It was FWD and all four wheels wore evenly. The Factory Pads lasted until 220,000 miles.
Shelbyv8
JD
I drive in Slippery Mode and it really helps the grabby brake problem.
