Maverick heating and air conditioning - driven electrically?
Hack
Hack
Sandia Park, NM
2005 & 2018 Honda CRV
I assume the air conditioner is driven electrically. What about the heater?
Portcqb
Eric
South Portland, ME
2025 Ford Maverick Lariat Hybrid AWD
Hybrid or Eco they have different systems
Decayed
yes
a car
Hybrid = Electrically driven AC compressor, traditional heat
EcoBoost = Belt driven AC compressor, traditional heat
The part in red means it's off every time the auto start stop cuts in.
DryHeat
DryHeat
Arizona
Jeep Patriot
Well... yes... but I don't think that means what you think it means.
(Note: I am assuming it means you think that the auto stop will cut in and turn off the compressor, leaving you to bake in the heat. Because if you don't mean that I can't really make sense of your comment.)
Anyway, the manual says the engine doesn't cut off if it is needed for climate control. So, yes, the compressor will be off when the auto stop cuts in. But the auto stop won't cut in if the compressor needs to be on. So this is one more thing you probably don't need to worry about.
Ford Maverick Maverick heating and air conditioning - driven electrically? 1639445293631
Decayed
yes
a car
That's interesting, I hadn't seen that, thanks. I've heard that complaint about this type of system in the past, apparently it's been addressed.
DryHeat
DryHeat
Arizona
Jeep Patriot
Of course, the next question is how well does the computer do in figuring out when the ICE needs to be on. I'm getting a hybrid, so I won't be in a good position to check that.
My guess, though, is that it will work pretty well. If not, there's going to be some really mad people down here in Arizona when the temps get over 110 degrees.
Decayed
yes
a car
Some A lot Most of my information is either old or secondhand. Hopefully things have improved.
This kind of issue is not new. A/C used to cut out on some older vehicles because engine idle RPM was too low to run the compressor. All I ask is some control over the situation.
clavicus
We had a Great Debate thread a while ago about hybrid heating. It’s now clear that the engine provides *all* heat, but there was much opining about whether there was an auxiliary heating element also. Some fuses existed for heat but it turns out those are for seats, steering wheel, mirrors, etc. There is no hybrid heating element, its all engine.
mamboman777
Josh
NRH, TX
I thought the heat pump could work in reverse. My house operates that way. In summer it's AC in winter, it reverses and is a heater, unless it's below a certain temperature.
Is that not the way the heat pump works?
clavicus
As far as I understand, the AC compressor doesn't reverse flow for that functionality in this vehicle. I think other hybrids may be set up for that but not Mavericks or Escape hybrids.
Shay
Sam
Phoenix, AZ
www.youtube.com
2022 Ford Maverick XL Hybrid (sold)
Correct. That's why auto-start-stop SUCKS.
Granted, when temperature is hot enough outside/inside and you have your HVAC set for a significantly lower temperature the computer will suspend auto-start-stop depending on the severity of the temperature difference.
My experience with other Fords is that their system is very aggressive and even in 110 degree heat here in Phoenix, if the inside temperature wasn't set to LO or the system set to MAX the engine still shuts off and leaves you with stale gym-sock smelling air for a period of time. It's really a sign that humanity is in its end days. :p
Egz
Fredericksburg, VA
2022 Maverick Hybrid Lariat, 1967 Fairlady
Got a F-150 from Lowe's and it had start-stop. Very annoying in a gas engine. Come to a light, shuts off, starts up 5 seconds later because the AC stopped and the cabin started heating up past the temperature limit.
Start-Stop really only works in a hybrid setup, IMO.
