Lowering your Maverick
CurtsCool
Curt
Oceanside California
2023 Maverick XLT
I have a 2023 XLT Hybrid. Has anyone used Eibach lowering springs and have zero problems? Do I need the alignment bolts with the lowering kit? I’m hearing some stories on here of noises after having the kit installed. Anybody have everything go smooth?
No noises/clunking? Any positive results? Thanks fellow Maverick owners! Stoked on my new ride!
Ford Maverick Lowering your Maverick IMG_1484
Tug Toy
Jay
22 Mav Xl, 86 f250 4x4 xl, 91 Ranger EC 4x4
That was the first generation of front springs. The ones that come in the kit now don’t have the minor noise problem. Your alignment shop should have the 14mm camber bolts in stock when you take it for alignment.
Bargeld
Wake Forest, NC
2023 Maverick Lariat Hybrid Oxford + Black + Lux
I had my Eibach springs installed 1 week ago, using the Eibach camber bolts. I printed out a little snippet from the forums with pics of the bump stop locations, just to make sure there was no confusion.
The installer said he had to align it 3x and that the oem camber bolts would have made aligning it almost impossible.
No noises at all.
I've had Eibach lowering springs on my Nissan Juke for literally a decade and they have been completely issue-free.
22MavXLT
NC
22 Mustang GT, 23 Maverick XLT AWD
Mine is AWD but I has the first gen Eibach's and they made the noise. Now have the new revised ones and no noises. Super happy now. Mine aligned within the spec range with no camber bolts. Sure there is some camber in the rear but it's not bad enough I would spend big money for camber arms or anything. I will just change tires sooner than most people.
CurtsCool
CurtsCool
Curt
2023 Maverick XLT
No noises at all.
Whats the trick with the bump stop location? Please
Bargeld
Wake Forest, NC
CurtsCool
CurtsCool
Curt
2023 Maverick XLT
MikeyG
phila
What about longer sway bar links? I saw somewhere that lover sway bar links are needed.
Jman79
North East, USA
Honda Odessey, Ford Maverick 🤞MY24
Are there any functional gains to lowering or is it mostly aesthetics? Eg. Better mileage?
I guess it would make bed access easier.
clos0791
Carlos
Maverick Lariat, Alto Blue AWD
How can you tell if you have the new revised springs? I just received my lowering springs a couple of days ago. 23 Lariat AWD. Thanks.
clos0791
Carlos
I would say mostly aesthetics but you do get better handling, lower center of gravity.
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
The most notable thing is obviously aesthetics and improves handling, but I did notice a slight mileage increase (which is not enough to justify doing just for this).
22MavXLT
NC
If you have the old springs you will have a rubber/plastic isolator around the coils in the middle, where as the new revised springs don't have that.
clos0791
Carlos
Thanks.
