Lasfit Switchbacks overheating?
g1zstar
NY
XL Hybrid Barebones
Anyone else with Lasfit have weirdness occur after leaving the turn signals on for a few minutes (XL/XLT)? Multiple occasions where I'll have the hazards on and when I come back to the car I notice some oddities.
While having hazards on:
Then on "phase" being shorter than the off "phase". Where normally they stay on for 1.25 seconds and then stay off for another 1.25 seconds for example, it seems to be more like 1 second on 1.25 seconds off. (No hyperflashing on the dash though)
One side turning off an instant before the other one.
While having one turn signal on:
Same timing irregularity as above but in addition hyperflashing on the dash. (No actual hyperflashing on the light though)
I have Alla's for the reverse lights, and Lasfits for the cargo lights and obviously the turn signals. Side Markers and 3rd Brake Light and the rest still stock. Although I think the issue is due to the lasfits turn sginals because looking at the back the stock bulbs seem to have a normal timing and doesn't seem to be running fast.
If I leave the turn signal on, it won't seem to fix itself until I leave it off for a bit. Ex: I park near the fire hydrant temporarily while I grab something from my house. Come back in about 2-3 minutes and notice the lights behaving different. Get in, switch the hazards off and left turn signal on to let people know I'm rejoining traffic. Experience said hyperflashing, turn signal turned off, drive a bit under 3/4 of city block, turn signal on again for turn, still experiencing hyperflash. I have to give it about 20-30 seconds for it to cool off? I guess.
Ford Maverick Lasfit Switchbacks overheating? 1646721012302
Ford Maverick Lasfit Switchbacks overheating? 1646721018119
6 frames of this
Ford Maverick Lasfit Switchbacks overheating? 1646721046578
Ford Maverick Lasfit Switchbacks overheating? 1646721053473
Ford Maverick Lasfit Switchbacks overheating? 1646721059225
Ford Maverick Lasfit Switchbacks overheating? 1646721065415
Another screencap of that video where it's in the opposite order
Ford Maverick Lasfit Switchbacks overheating? 1646722104828
but there are also occasions where they both turn off together in sync.
I'm assuming this is not normal because naked eye can perceive it. (I was saying I couldn't tell in the video but if that were true I wouldn't be recording hahaha) and the fact that they seem faster in general and this only happens when I leave them for a couple minutes.
Ford Motor Company
Official Ford Account
Dearborn, mi
6 frames of this
Hi there! Can you send us a PM with your VIN and Ford dealership information? I’d be happy to look into this Maverick concern on my end.
Finklejag
WA
You install cheap Chinese aftermarket LED bulbs where OEM incandescent bulbs were installed. Now Ford knows you probably fried your electrical system. Great job!
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
Very unlikely the lower wattage lower amperage LED bulbs fried the electrical system.
g1zstar
NY
XL Hybrid Barebones
Response from lasfit cs
Thanks for your detailed feedback.
Yes, that is a normal phenomenon, it is the design of intelligent temperature control, considering the life span and canbus function.
Our bulbs have resistors built in to avoid hyper flash, once the bulbs are used for a few minutes (2-5 Minutes), they will reach a high temperature and hyper flash/out of sync, which is the safety feature to avoid our bulbs burning out quickly.
Please turn off and cool for 1-2 minutes, they will work again.
Guess it is intended. Bothers me a bit but not a deal killer.
MLowe05
GA
Lasfit quality is top notch and in my experience you get about 7 minutes of continuous use before they behave oddly due to temp issues. We have used Lasfit canbus LEDs in many cars and never had issues.
ShadowBlack XL440
Robert
Northern Ohio
6 frames of this
Your truck is just winking at you.
g1zstar
NY
XL Hybrid Barebones
Unfortunately for me 2 minutes with the hazards on and they behave oddly
testa422
Charlotte, NC
Subaru Legacy
Lmao. Nothing is fried. Typical internal canbus led behavior albeit quicker than usual
Enderet
Oh no. I saw this thread today and thought, "poor guy, got defective LEDs," because I have had mine for over a month and havent had anything funky happen. Well, I was sitting at a stop light today, and after a while of sitting there with my left blinker on, boom, hyperflash.
It bummed me out. 10 seconds later I was turning right, and when I turned that blinker on it didnt hyperflash. Turned left with the blinker on, no hyperflash. But... I then sat in my driveway and left the left blinker and started counting. After 75 flashes, it broke into hyperflash. I didnt test the right side. One thing that I believe I noticed is that as I got closer to the 75th flash, the blinking was slowly getting faster.
Oh and just to be clear, I was only checking the hyperflash in the dash, counting the clicks. I did not check to see if it was also hyperflashing outside (as in the led itself).
In case it matters, it is about 75degrees outside today.
mdl20813
Idaho
Cactus Gray Maverick XLT
literally the same exact thing happened to me today. I didn’t do any further testing though. Had mine for 2ish months with no issues before today
Adospeed
Ado
Colorado
Hybrid in Shadow Black
I pulled my LASFIT LED front turn signals out this past weekend for the following reasons:
1. They were over the top bright at night lighting up street signs across the intersection, and glaringly bright to oncoming vehicles, as well as being behind someone with the blinker on.
2. Waiting to turn left for an extended period (kid pick up at school) and it would start blinking really fast, the same hyperflash some have mentioned.
3. I'm just not willing to risk issues with that many lumens and first hand problem experience with them.
Chris_G
NOVA
C-6 Corvette
Hopefully Lasfit will make it right for all of us that purchased them.
Chris_G
NOVA
C-6 Corvette
They weren't that cheap.
