Lasfit Customer Service Warning
GTIgus
August
Kitsap, WA
2024 Maverick Lariat Tremor, 2020 Ram 2500 CTD
I recently decided to upgrade the bulbs around my 2024 Lariat Tremor with Last products based on their use by folks on these forums. According to their site the amber front turn signals should work without issue on my Mav, however, they don't even turn on. They cause hyper flashing immediately and don't even emit a small blink themselves.
I contacted Last about this and I have some real concerns. At first I was told I need to take multiple videos so they can troubleshoot the issue, then they responded and told me that their website clearly says the twilight bulbs are for XL/XLT only (again this is about front turn signal bulbs). I can't believe a company selling products like this doesn't have an immediate answer about the issues I'm having.
What really concerns me, though, is that all responses from them come in at 1AM (PDT) and whomever has typed the response seems to barely have a grasp on the English language. Also, in their Maverick Q&A someone asks about twilight bulbs being used on a Lariat and they respond with, "Yes, the signal/tail/brake lights work on a lariat as well"
710-oil-614
Cal
2025 Hybrid AWD Lariat
Are you upset that you possibly got the wrong bulbs or are you just one of those folks who totally discredit a person or organization because English is their second language?
Sounds like they've been responsive to your issue even if your initial purchase has not worked out. Their website is misleading and shows these bulbs should work on Lariat. Maybe they'll give you a refund so you can no longer deal with them.
GTIgus
GTIgus
August
Kitsap, WA
Sounds like they've been responsive to your issue even if your initial purchase has not worked out. Maybe they'll give you a refund so you can no longer deal with them.
I changed my wording for you pal. I hope you have to deal with someone on a technical basis that does not have the ability to communicate effectively with you, I'm sure it'll work out
710-oil-614
Cal
Sorry forum member, not understand why comment you so angry
Your time here will be short, but certainly memorable to those who see this.
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
Which part # did you buy? I looked at the website and they show different part #s for XL/XLT vs Lariat.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
I don’t know about you but this whole LED lasfit stuff is kinda boring after awhile. I don’t mind going back to stock bulbs when these gone kaput. But so far they have proven resilient.
GTIgus
GTIgus
August
Kitsap, WA
I purchased the "Combo package for Lariat," SKU: T-4257A+T-WT21W+L-T10A+L-T15+L-T15R which includes the front turn signal bulbs #T-4257A. Per their website, "For LED turn signal light, it's specially designed for the 2022-2024 Ford Maverick, built-in resistor. You can rest assured you won't see any error code gauge cluster lights. You don't have to do anything to the lighting module to make function well. You don't have to deal with an extremely hot external resistor."
mdl20813
Idaho
Cactus Gray Maverick XLT
I'll assume you've done the basics of flipping the bulb around and plugging it in trying the reverse polarity?
I'm sure Lasfit will get you squared away regardless. You know, once they are done having the nerve to employee people who may have English as a second language.....
dusty1787
Dustin
Wisconsin
2023 Maverick EB Lariat
I agree with you, that if mine go bad, put the stock bulbs back in...but I would wait until another company creates a better bulb that works with no problems (possibly lasfit if they make one that works before others do)...and put LEDs back in... but I attempted to put the stock (rear) bulbs back in, and there is such a night/day difference in the crappy stock bulbs vs LEDs....i dont know if i can keep the stock bulbs in... ugh.
dusty1787
Dustin
Wisconsin
There is a small chance maybe they gave the wrong bulbs and or the bulbs are defective. If you can look at the bulbs do they have the yellowish/white diodes on the bulb at all? Because those might be the switchbacks then....which should not work on the Lariat. Only the amber ones will...so there should not be any non amber color diodes on the bulb itself.
A.Bursell
Stanwood, WA
The only "advantage" to Lasfit is/was that the bulbs worked without hyper flashing. That's no longer the case, or sometimes the case, or works fine depending on individual trucks and bulbs - there are lots of different reports.
I suggest using Forscan to change two easy settings to disable the bulb out notification, and then you can use any company's bulbs - still without installing resistors. They can be $5 bulbs from eBay or a top quality brand name bulb, they will work. It's doubtful your bulb out notification would work anyway with any LED bulbs, so you aren't missing anything.
After having Lasfit, and returning them, my choice is Diode Dynamics and I am much happier and have zero issues. And if I did, I have a 3-year warranty and great customer support.
small chance? search this forum and FB groups, and you might think it's actually a high chance of problems.
dusty1787
Dustin
Wisconsin
I am aware of the fact there are posts and such on here with people having problems, but a handful does not mean everyone. I have no issues with mine...and seeing we do not know how many they have sold, 1% failure rate seems normal to me...5% seems within reason....10%or more...thats getting bad. But if all of the bulbs are failing and garbage, and they have a 1yr warranty...feel they should be going bankrupt/out of business if the products are that bad...
If you sell something for $100 that you paid $5-10 for, you can replace a lot of them under warranty and still be quite profitable.
Ozarkbeard
I don't understand the panic to install LED lamps. I see all sorts of crappy LEDs on cars & trucks. Flickering, hyper flash, way-too-damned-bright for just a fn turn signal indicator or brake light. Taillights that look like brake lights (are the riding their brakes or just have f'd up overly-bright taillights). The list is long. And then there's the Maverick's dangling taillight lens assemblies after repeated bulb changes.
I have no problem with the stock bulbs that came on my Maverick and will keep them until they fail (if they fail).
