Lasfit Confusion
Lone Star Proud
William
Central Texas
Ford Maverick XLT
I did the recall Tuesday on my 2022 XLT and got my new bulbs today. I changed them out and hyperflash is gone.
I would like to thank Lasfit. I have been using this first set of rear lights for almost two years. I really didn't think they owed me anything but they discounted the new lights by 50% when I asked. I am more than satisfied with their response and service.
smoreho2
Virginia
2023 XLT Hybrid (October 2023)
Do they have new light for the rear (t-3)?
First Sergeant
Fruitland Idaho
I had 1st generation LED Lasfits on all my exterior lights in my 23 XLT Hybrid. They worked great before the recall with no hyperflashing. After the recall, all bulbs worked normally on the exterior of the vehicle, but hyperflash started on the dash (inside). I wanted to change to the 2nd gen LED's on the front turn signal lights as I also thought they were to bright AND I read here that changing them helped alleviate the hyperflashing on the inside. I got them and installed them and while they are dimmer (yea), and work normally on the outside of the vehicle, they did NOT fix the hyperflash on the inside of the vehicle. Guess I am waiting for a fix of some sort as I will not give up on LED's at this point
The only thing causing hyper flash is the first generation Lasfit REAR bulbs. As far I as I know. I switched out ALL original bulbs to first generation Lasfits and no problems UNTIL the Software update. I only changed out my rear bulbs to the T3 new ones and problem solved. Everything works fine now. All my other bulbs are Lasfit Led, first series and all is good. Your mileage may vary!
smoreho2
Virginia
So what part number did you use for the rear 2nd gen lasfit bulbs? I was told they did not have t-3 for the REAR replacements
elizabethk314
Elizabeth
St. Louis
Escape
T-3 4257R is what they sent me and corrected my hyper flash on the dash.
Maverickent
Kent
Mason City, IA
I sent an email to customer service about the hyper flash and they sent me the lights T3-4257R. They worked for me
I'm having the same issue with the Lasfits after recall. I sent Lasfit a message through the chatbot, last week, but the only thing they've done so far was send me an email with my message to them. Maybe I have to go back on the site and try again.
First Sergeant
Fruitland Idaho
I don't do well with the bots. I just sent them a direct email. Vichan I think was his name there.
First Sergeant
Fruitland Idaho
First Sergeant
Fruitland Idaho
Do you have a Lariat? Some have said the Lasfit T-3 rear bulbs won't work on a Lariat at this time. I don't know for sure.
elizabethk314
Elizabeth
St. Louis
Escape
