Keyless entry for XL question. 2023 order
RatherBeDrivingaManual
GBP
Maine
NA Miata, Subaru Legacy, XLT Mav
Ford Maverick Keyless entry for XL question. 2023 order Screenshot_20220801-173707_Chrom
Hello. I've been trying to pre plan my 2023 XL order. I would like to add the key less entre feature. However when I option it, it shows up as a dealer accessory and the details show "no-drill installation".
I get every option I add on could reduce the chance of being built. Anyone know more details about this option? Does it just glue onto the door?
Jatrax
PNW
2023 VW ID.4
Look like its just a big key fob type device. It gets programmed from your key fob and then they just glue it to the truck.
paneubert
Seattle
Yes, it just sticks on with very strong tape. Same with all the other keyless entry pads on the Maverick.
Tailender
Will
Poconos
I'd like one that goes on vertical so I could put it on the door pillar but I can't seem to find one.
WannaMav
Hawaii
2022 Maverick hybrid
Frankly too lazy to go look but there's at least one thread about keypads with various entries about where people have placed them.
Oh, do take note there are two separate part numbers - one for vehicles without factory remote start (like the XL) and a different one for vehicles with factory remote start.
Bob The Builder
Butch
Vermont
The wireless keyless entry pad is horizontal mount only. No vertical option available. The old models without the little LED indicator light above 9 - 0 was easily programed doing the on-off-on ignition switch program. The later ones from 2014 or so require programming from the dealer which costs around $100 bucks or so on top of the keypad. Some may know someone who has the proper tool to do it and save $$$ but for the rest of us it is an expensive proposition.
The keypad can be places anywhere you want. Some put it inside the gas door if that would work on the Maverick. Others inside the bed but that would be not so handy with a Tonneau. I saw a Bronco the other day with one in the usual boring spot above the door handle.
Gpp
Gil
Sanford nc
2022 ford maverick
If you’re using it as a emergency entry to get in car just either put it in the rear cubby of the bed or stick a good magnet on the bottom and put it up under the bed rail behind the driver.
DJLG210
LG
San Antonio
2024 XL AWD
FYI the battery is not replaceable. You have the buy a whole new keypad unit when it needs to be replaced. The factory installed keypad is hardwired to the truck.
GBP
Maine
Oh wow. Is that the xlt that gets the hard wired?
DJLG210
LG
San Antonio
2024 XL AWD
Yes. XL is only trim that does not include a keypad.
Bob The Builder
Butch
Vermont
I did manage to take mine apart on the Ranger twice to change the battery. First time I was successful. The second time for some reason I did something to the unit that caused a parasitic drain which caused the battery to go dead after a few days.
DJLG210
LG
San Antonio
2024 XL AWD
I wouldn’t let the battery thing stop me from getting one though. Just something to keep in mind. The battery should last quite a bit longer than a standard key fob battery does.
NeedForSteve
Eastern NC
2007 Fusion 2.3; 2023 HPR XLT EB
I have one of these sticky pads on my Fusion. The tape is strong as hell, you're not gonna lose it and the battery is meant to last something like 7 years I think? I've had mine for almost 6
