Issue: exterior temperature stopped displaying and CEL light on
GregS
Greg
Russellville, Arkansas
2007 Honda Ridgeline
I took delivery of my Ecoboost Mav three months ago, and have been very been pleased. But, just today, I've had a little hiccup that I'm thinking a forum member might be able to save me a little time with. The exterior temperature stopped displaying (which triggers a check engine light, because the auto start/stop can be tied to this somehow). I'm really guessing, because of the newness of the vehicle, that a connection just rattled loose -- anyone know where I can look for this under the hood? I'd love to check the connection myself before having to set up an appointment and take it to my dealer! Maybe someone has already experienced a similar problem?
XLTLUXA51
Ezra
Hardwick Vermont
Ninja 650r, Suzuki SX4, Buell blast 500
Shoot! I’m really sorry to hear about this. Best of luck. Unfortunately I have no clue where the connection is
bbhaag
Greg, this sounds like a warranty issue to me. Call the dealership and make an appointment to get it looked at.
If you are wanting to try a DIY approach though. Try disconnecting the negative terminal on your battery for ten minutes.
Decayed
yes
a car
Seriously, if you look under the hood but don't see anything obvious, just call the dealer. This sounds like the kind of esoteric problem that the service people are better prepared to deal with.
Big_T
T
2022 Maverick XL Hybrid
The temperature sensors I've seen on other vehicles are at the back of the grill. But it's best to just make an appointment with your service department for warranty repair.
Vongreg
Greg
Arkansas
Hybrid Camry, chevy 2500 HD, Maverick Hybrid
On an Escape it is located on the lower front fascia on the passenger side. You will probably have to take the front fascia off to get to it. Not 100% sure on this
https://www.roadmasterinc.com/pdfinst/524465-4.pdf
page 8 mentions it
i would take it in
The Weatherman
Dean
KY
What @Big_T said.
dceggert
Metro Detroit
2017 Fusion, 2019 Ranger, 2024 Maverick ordered
Most of the new Ford vehicles have the outside air temperature sensor inside the passenger mirror. I am not sure if the parts diagrams are online at Motorcraft yet but when they are it is a great resource for finding stuff.
Edit: It looks like it clips to something so more than likely underhood on the Mav. I could not find any assembly diagrams but this is what the part looks like at parts.ford.com.
Ford Maverick Issue: exterior temperature stopped displaying and CEL light on 1641864899308
ffoc01
2022 Mav Hyb FE, 2014 Flex
I agree with the other posters, this seems like a dealership issue. You don't want to start messing around with anything that could make a dealer not want to cover a repair under warranty.
That being said, that Ambient Air Temp sensor is behind the lower half of the grille, just off to the passenger side. Officially, the bumper cover has to come off to access it. There's the connector on the sensor and a second bulkhead connector for the front bumper harness (AAT sensor and the marker lights) inside the Pass front wheel well.
notfast
Los Angeles CA
That's got me curious. What other Ford vehicles? The passenger side door mirror seems like a very odd placement for a temperature sensor. There's little airflow in there since the only ventilation is the gap around the mirror glass.
ffoc01
The Super Duty has had it in the mirrors since 2011, the F150 since about 2017, The Focus, Escape, CMax have had the sensor under the mirror since 2012/2013 respectively. The sensor is actually under the mirror housing, in direct airflow.
Having the sensor there makes it less susceptible to the heat coming off of the radiator and condenser when the vehicle is stopped.
06Warrior
Person
19' HD Road Glide, 22’ Sporster S
Have you tried disconnecting the battery for about a half hour to an hour then reconnect to see if all goes back to normal?
GregS
Greg
Sounds like I've got a good strong consensus just to take it in to my dealer -- which I've got an appointment to do! Thanks for the input, folks. I'm sure not comfortable removing the front fascia to troubleshoot this problem. Just thought it might be somewhere easily accessible that I could wiggle a wire on . . . but I'm not prepared to do what it sounds like it would take to reach the sensor.
jicajust
Westfield, IN
2022 XLT Maverick
I'm having a outside air display issue on my Hybrid XLT as well. Recently, the computer downloaded and installed over the air a software update G1.8.0.1_RC15_R21461a. I'm not sure what this update was addressing but since then, the Infotainment display has been real glitchy. The temp display has locked at 37f. The backup camera is on going forward for a short period and the display locks up and is unresponsive. I've checked for more updates over the air but that process is iffy at best. I'm heading to the dealer today for some more information. I haven't tried a master reset yet but we'll see what the dealer says.
AnthonyMav
Anthony
New Jersey
Maverick XL Hybrid
My CEL just came on and the temp says “——“
what was the final resolution to this from your dealer? New sensor or broken wires somewhere?
and I assume this means the Auto climate control will not work now. The AAT is needed for Auto climate to function properly and read the outside temps.
