Issue: Automatic Dome Lights Not Functioning
nunucello
Marcello
New York
Interior dome lights no longer automatically turn on when opening door.
Either exiting or entering the Maverick - automatic dome lights no longer functioning
Dome lights will work when manually pressing them.
Dome lights will work when using the center toggle switch.
When running the car the battery voltage displays 15.1 volts.
Maybe I should reset the 12V battery management system ?
Any advice is appreciated. Thank You
Redneck Garage
Franklin TN
www.theredneckgarage.com
Same Here
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Sounds like typically deep sleep problem sadly. Mine does that sometimes as well. I sure hope Ford does a recall on these 12v batteries, this is a joke.
nunucello
nunucello
Marcello
New York
You are correct - I just looked at my Ford Pass App - and I have multiple Deep Sleep messages.
Maybe its because I have been using the heated seats and heated steering wheel 100% of the time when driving ?
Thank You for the quick response.
icegradner
Could be, hard to tell. Sometimes using them seems to make a difference other times it doesn't. I think it hits the 12v harder when you haven't been driving as much. I usually start at 2 and go down to 1 bar, on the seats, they get hot. Steering wheel is the same, once it's toasty I turn it off for a while till it starts to cool. Seems to help.
It started show up for me before I even used those features though, so I don't think that is the core problem.
uga
SE USA
2026 Ford Maverick XLT
Try turning off wireless and auto updates, worked for me...................................
Surprised the Mav made it thru 7 degrees and started
Ford Maverick Issue: Automatic Dome Lights Not Functioning 7
nunucello
nunucello
Marcello
New York
OK - thank you Icegradner
nunucello
nunucello
Marcello
New York
Great idea - thank you Uga.
icegradner
Thankfully the hybrid only uses the 12v system for the computers, lights, radio. The hybrid battery pack powers the electric motors that turn over the ICE.
I turned off Fordpass, wireless etc months ago. Still seems to be a problem.
uga
SE USA
Sorry to hear that, it seems something keeps draining the 12 volt battery
nunucello
nunucello
Marcello
New York
12V Battery voltage is 12.28 when the Maverick is off
12V Battery Voltage is 15.2 when the Maverick is running.
Does not look like battery is low or drained - i dunno.
icegradner
Deep sleep only goes on for two reasons. Long periods of not driving, or if the battery is sitting below 50% charge.
nunucello
nunucello
Marcello
New York
Thank You - do you mean the 12V battery for the Hybrid battery ?
nunucello
nunucello
Marcello
New York
12v battery, not the big lithium ion pack.
OK - maybe I have a funky battery? Even though it displays a good charge of 12.28V with a voltmeter.
