Is trailer side view possible without a trailer?
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
KenE
Ken
Tha k you Russ for the update, info & link. And thank you MM for reiterating that the small current draw from LED light will trigger the "Full charge".
Unfortunately I'm going to pass for now. I notice this item is frequently returned for compatibility issues, primarily hyperflash & turn signal error msgs. That's what I experienced with the other unit I tried, and I could not find a way to overcome with FORScan. I was able to stop hyperflash but not the persistent error msgs, and loss of reverse gear lane markings & warnings. I was hoping to force "charging tricks" discovered by Mavster Mechanic w/o using lights. So, back to using lights, which absolutely works.
saveup
Russ
Kingston Oklahoma
Ford Explorer, Ford Bronco
Sorry to hear. I have had this installed for a couple of months with NO issues.
KenE
Ken
Russ I'm guessing it's a 2026 vs 2025 model difference. I was so hoping to use a plug in device for additional rear illumination & full 12v battery charging w/o side affects. I'm not giving up but now have no workaround. Just the loss of Reverse backup assist lines would be a no-go for my wife. And, if wife not happy, we all know. Lol. Good luck. Oh, do you really have an option in trailer setup for height? 25MY doesn't.
saveup
Russ
Kingston Oklahoma
Ford Maverick Is trailer side view possible without a trailer? 20260816_193713
BK007
BK007
OH
That's why i added tow mirrors...🤷‍♂️
Ford Maverick Is trailer side view possible without a trailer? 76134746-a97b-479a-8c0c-96e6ef8e71d7
KenE
Ken
That explains it. 26MY has expanded trailer parameters that must allow things to work that are inhi item on the 2025. I just have height & width. Thanks and enjoy your ride.
