LED trailer light help.
Mdavis
Michael
2024 Maverick XLT
Hoping someone can help. 24 ECO XLT. I pull a small flats boat occasionally. The trailer has LED lights. When starting up, I get a message that says trailer connected. Cool. But then not connected, and back and forth. Then warning for turn signal fault. So lights on trailer work, then they don't. Off and on the whole trip. Replace all lights and wiring. Same issue. Grounds are good. Will load resistors fix this? If so, do I need 3? Left signal/brake. Right signal/brake, and running lights? Any help is sure appreciated.
BK007
BK007
OH
Trailer module reprogramming
Schedule your free recall service with a dealer.
The dealer might be able to complete the service at your location or pick up your vehicle and return it when the service is complete.
Issue Date
2026-03-18
Campaign
26C10/26V104
Description
On your vehicle it is possible that the trailer module trm may lose communication at vehicle start-up. If a trm loss of communication occurs and a trailer is connected to the vehicle, trailer stop lamps and turn signal indicators will not function. Additionally, for trailers equipped with electronic trailer brakes, the trailer brakes will not function. This loss of communication can occur with-or-without a trailer connected to the vehicle and can only initiate at vehicle start-up. If this occurs, a trailer brake module fault notification will pop-up on the vehicles instrument panel cluster. The vehicle brake and turn signal lamps will continue to operate normally and are not affected by this trm fault. If you do not tow with your vehicle, you may wait for ota deployment for your vehicle remedy.
Safety Risk
This may result in inoperable trailer brake lights, trailer turn signals and trailer braking functions that can reduce a drivers ability to control an attached trailer and make the trailer less visible to other drivers, increasing the risk of a crash.
Remedy
Software is available to repair your vehicle. Ford Motor Company has authorized your dealer to reprogram your vehicles trm free of charge.
Next Steps
Contact your dealer for more information to schedule the free service.
FordDiehard
Paul
Central VA
2017 Ford Focus, 2023 Maverick Lariat
A mobile technician from the Ford dealership where I bought my Mav came out this morning and completed the 26C10 recall. I was told they submit them to Ford for payment, and it takes 24-48 hours before it will show up as done.
Mdavis
Michael
2024 Maverick XLT
Issue Date
2026-03-18
Campaign
26C10/26V104
Description
Safety Risk
Remedy
Next Steps
Thank you so much for the reply
Doccus
AL
2025 Ford Maverick Hybrid XL
2025 Hybrid had same problem. The trailer module update done OTA did not fix problem. I took it in and they re-did the update and all is well. Took less than 30 minutes.
Mavster Mechanic
Hybrid
Sounds like either / or both remedies would work.
Sounds like current draw of your trailer is too small. Resistors or adding additional LED lights or a single incandescent light would solve this.
Also sounds like the reason for the software recall was to modify the current to detect a trailer threshold.
Explains why I never had trailer light issues in 4 years of towing. Both my trailers have LOTS of lamps.
