Is trailer side view possible without a trailer?
saveup
Russ
Kingston Oklahoma
Ford Explorer, Ford Bronco
Has anyone found a way to enable trailer side view without a trailer connected? I know it works with a trailer connected to the 7 Pin outlet. I have not checked with just a 4 Pin trailer connected, so I am not sure what enables the cameras. I'm thinking it is when the Trailer Brake senses a connection.
I have a 2026 Lariat Hybrid, with 4K Tow package.
saveup
Russ
Kingston Oklahoma
Thanks. I tried to search first but must not have had the search terms correct.
Russ,
You may consider sending a DM to the posters in the other thread.
And see if they've come up with anything that they haven't gotten around to posting yet. You never know🤷‍♂️
Maverick123
25 hybrid
1) Press the camera button
2) in the top left corner of the screen, you'll see a white button, press it to select different views (front, rear, trailer split view, etc)
saveup
Russ
Kingston Oklahoma
In case anyone is wondering.......
I installed a lighted trailer hitch cover and connected it to the 4 pin plug. Now when I turn on my blinkers, the camera on my mirror shows the side blind spot.
I did lose the rear parking sensors when in reverse, but still have the camera.
Ford Maverick Is trailer side view possible without a trailer? 20260510_185620
Ford Maverick Is trailer side view possible without a trailer? 20260510_185844
Nice. I like the side view.
By sensors, do you mean the white backup lines?
I understand you have the side view camera.
Did you also lose your BLIS Blind Lane information system?
saveup
Russ
Kingston Oklahoma
No, just the backup sensors that beep when you get close to an object. Still have Bliss, cross traffic warning, and lane centering. I did add information to the trailer tab and set it for the lowest settings. 3 foot length, 1 foot wide, and 1 foot tall.
Maverick123
25 hybrid
Wait, the middle screen shows the side camera view when you hit the blinker in reverse with a trailer connected?
I've never noticed this. I guess I never signal when backing up a trailer ...
saveup
Russ
Kingston Oklahoma
On my 2026 Lariat Hybrid with 4K Tow (not sure what options activate this feature), when you turn on the blinker with a trailer attached, the camera on the side mirror shows the side "blind spot" on the sync screen.
I liked this view but it only worked with a trailer connected, so I added a lighted hitch cover to make the truck think it had a trailer connected. Now the camera on the mirror displays the side view on the display any time I turn on the blinker.
Maverick123
25 hybrid
I've got the same, but 2025. Does this only happen in reverse, or does it happen in drive also?
On a different topic, I've noticed is that the "trailer aware" BLIS only works on the passenger side. On the driver's side, the BLIS doesn't light up until the passing car gets within 3 feet of the truck ... It doesn't monitor the trailer's length. Anyone else?
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
I have a 2025 Lariet. Ordered a LED 2" receiver light bar. It works as advertised, but... Tail lights are still OEM, was getting hyperflash with turn signals, and "Turn Signal Errors". Set it up as a trailer with length of 3', width of 1', which allows BLIS, but the rear backup lines are gone. I was able to eliminate Hyperflash with FORScan, but the Left/Right turn signal ERROR msg pops up for a second on main screen, even flashing normal speed. Losing the backup lines and the persistent Turn Signal Error msg on driver's screen makes it a NO GO for me. Plus, the turn signal didn'tforce the left or right side camera view on the 13" screen, which I wanted, which some posters achieved. I'll be returning the light bar to Amazon I guess. If anyone has suggestions I'm all ears.
KenE
Ken
Russ, I have 25MY Lariet 4K tow. I could not achieve the turn signal left/right cameras. I set trailer length 3', width 1'. But I don't have a height setting to change as you indicated? Maybe that's a 26MY change? Also, is your receiver light LED or a larger wattage bulb? When i plug a LED light assy in the 4-pin connector (includes turn, brake, running), I get hyperplash with turn signals & error msg on dash indicating turn signal outage. I also lose reverse parking aids but retain BLIS. Does your light have just two wires or four? Thanks.
Mavster Mechanic
Hybrid
BONUS: your 12v battery will stay fully charged and last many years.
