Dallas Maverick
Dallas, USA
Volvo
Something I've been planning for a while and haven't had the time or chance till now. Going camping soon so I thought now is the perfect time. Wanted a clean, flush look. Like if it would be a dealer option. Haven't wired it up yet. That'll be tomorrow. I'm going to put a temporary switch and go with something like switch pros later down the road.
Reminds me of this:
https://performanceparts.ford.com/part/M-15200K-EGL
Ford Maverick In grille light bar install 1666723453954
Hdang1980
Elk Grove, CA
2022 Ford Maverick Hybrid
Were they 10mm sockets by chance?? :ROFLMAO: :ROFLMAO: :ROFLMAO:
I can't remember for sure. I hope to never have to find out again though. I removed the grill bar to plastidip spray it. When the time comes to peel it off, it should be pretty easy without having to remove the grill bar again. *fingers crossed*
G19Tony
Tony
Las Vegas
2025 Ford Maverick XLT, 1994 Ford F150
That’s pretty cool. If you can make a red light move back and forth like a Cylon, that would be even cooler. 😎
MTBMav
Monterey CA
2022 Maverick Lariat Alto Blue
If you want sequential turn signals in yellow (match OEM signal lights) and straight white when you run the headlights you can use these. They worked well, a bit expensive but went in easily and work exactly like they are supposed to. I used a discount code FLASH20, give it a try. Shipped a few days after ordering. The lightning light bar is a custom look. It looks like the F150 Lightning's little brother. I get comments as they do a quick light show on startup. Refined Truck supplied the lights.
Used Cloth wire tape just like OEM wrap. The connectors shown below work well. Wrapped everything up neatly and it looks OEM. Doing both at same time minimized some connections. All availablefrom Amazon
Your order from Refined Truck is confirmed.
Thank you so much for your order! We are a new small business that really appreciates everyones support! Right now it is just me and my brother doing everything, but we are going to do everything we can to get your order to you as quickly as possible.
Again, thank you for your support, it means everything to us!
If you have any questions, or just want to chat about something, feel free to reach out to us!
You can find us @2Randomscrubs on Instagram and YouTube
Once your package ships we will send you a notification email.
Order Summary
Order XXXXXXXXXX
Placed on July 11, 2022 at 9:19 PM CDT
Ford Maverick In grille light bar install tempImage4rdLP1
Ford Maverick Lightning Style DRL$80.00
SQ6018250
Trim: Hybrid Lariat
Qty: 1
$80.00 / Item
Delivered August 3
Your package was left near the front door or porch.
Ford Maverick In grille light bar install 51E6Y7+KxsL._SS284_
XFasten Wire Harness Tape, 3/4-Inch by 50-Foot (3-Pack), High Temp Wiring Loom Harness Self-Adhesive Felt Cloth Electrical Tape for Automotive Engine and Electrical Wiring
Return window closed on September 2, 2022
Buy it again
View your item
Ford Maverick In grille light bar install 41w9rk7K6xL._SS284_
Low Voltage Wire Connector, BRILLIANCE4U Quick Wire Splice Connector, 3 Way T Tap Solderless Wire Connectors, Ideal for LED Lighting, and Automotive, Fit 24-18 AWG Wires, Half Transparent 12 Pack
Buy it again
View your item
Ford Maverick In grille light bar install 51alrO8KcwL._SS284_
Wago 221-413 LEVER-NUTS 3 Conductor Compact Connectors 10 PK
Uselessness
Uselessness
An
San Jose CA
2022 Ford Maverick Lariat Fx4 (1/10/2021)
They should be 7mm or 1/4 sae
Uselessness
Uselessness
An
San Jose CA
Order Summary
Order XXXXXXXXXX
SQ6018250
Trim: Hybrid Lariat
Qty: 1
$80.00 / Item
Delivered August 3
Buy it again
View your item
Buy it again
View your item
I used to have a shop customizing cars I'd rather bake the headlights open and install them into the eyebrows, making the switchback sequential while leaving the oem incandescent bulbs so you don't get any errors in the canbus system. You'd also need to install a relay cutoff to the oem DRL with a resistor to trick the canbus system on each headlight. Similar to the Audi's rear oem sequential.
MTBMav
Monterey CA
The lights suggested have the board builtin to the lights. They are LED and very low watt draws. No Canbus errors and the turn signal activates the orange sequential action. When no turn signal active and the headlight on it turns on the white light as well, Pretty slick.
Uselessness
Uselessness
An
San Jose CA
They are no longer on the website. I was going to take a look but link is broken and couldn't find it on the website homepage.
Uselessness
Uselessness
An
San Jose CA
You can also run a relay and get signal from the fuse box and use a fuse tap to a ignition controlled fuse and power it though the battery that way it'll always be on when the vehicle is running and off when the vehicle is off regardless of the headlight switch position. (Like oem) spdt relay are available at any car audio/alarm shop
2022EOW
Marty
Missouri
2014 Focus
Great, more unnecessary lights to blind oncoming traffic.
Uselessness
Uselessness
An
San Jose CA
Deadangels84
Pennsylvania
Here it is in the day. They are bright as hell at night. I'll post a night pic when I get a chance. Works been crazy with 3 jobs.
I gotta find a way to hook them up to the high beams. The wires going to the headlights are digital signals so I need schematics or something to figure where I can tap signal from as I want them to work with the auto high beams. If anyone knows anything please chime in.
I'm looking for a way to add lights to mine so they pass PA inspection (off with highs on) and found some dude on Ebay who made a harness for me to try out based on what I think will work.
Essentially it's a pass through harness with jumpers for the high/low signals. Can't tell you if it actually works yet or not, literally just had it made and received. Too cold now to mess around with.
However, it looks like he's going to be making more based on my idea. May want to check into it or at least reach out to see if he has a solution that would work for you.
https://customautoworksstore.com/?s=Maverick+&post_type=product&dgwt_wcas=1
Uselessness
Uselessness
An
San Jose CA
Thnx I'll contact them!
LSchicago
Lloyd
IL
In most states there is a limit to the amount of white lights that can face forward while on roadways. Many of these are limited to four.
Illinois also allows a pair of "cowl lights" works out well for the jeep guys. Probably a 100 year old law.
