- First Name
- Cal
- Oct 13, 2021
- Ohio...but I'd rather be in Boone.
- 2025 Hybrid AWD Lariat
- Engine
- 2.5L Hybrid
I just installed mine after watching @Shay's video on the install.
Most (if not all) of the bolts in the Maverick's bed are Torx PLUS - which Harbor Freight does not sell.
This was likely the source of OP's issue with getting the bolt out which is definitely torqued in there with some loctite.
Also - maybe it has changed my bolt took a TP-45 and fit like a glove. As a big user of impact drivers - I would recommend NOT using one here if you experience trouble getting the bolt out use a breaker bar.
I 100% would not do this. When installed correctly there is plenty of tolerance - close to a 1/4 inch between the screw and damper.
Here is another little tip that may help anyone installing the tail gate assist.
