Hybrids with 235/65R17: Impressions?
SeanBonham
2022 Maverick Hybrid XLT Lux
10/32 tire tread brand new is why. That's pretty lame when most decent ATs are at least 12/32nds. No 3PMSF rating either.
Are you running Outpost ATPs on your hybrid? That is the other tire I have considered. How are the MPGs?
JimmyH
Jimmy
2023 Ford Ranger XLT; 2023 Kia Sorento EX Hybrid
Thanks for the heads-up. I believe the Toyo 235/65R17’s weigh 32 lbs. The Falken Wildpeaks in that size are 31 lbs. I *think* that the stock 225 Continentals weigh 26 lbs. Definitely a step up in weight, but I’m pretty sure it’s one of the lightest options.
Does anyone know of an AT tire that’s lighter than the Toyos or Falkens?
I believe that Tire Rack shows the Firestone Destination AT2 in 235/65r17 to weigh in at 28 lbs. If I actually get a MY23, I was considering going that route. Would love you see some pics of them in that size on a Maverick.
Johnkn
MD
The highly-praised Wildpeak A/T Trail 225s are 11/32” and weigh 25% more than the Crosstrack ATRs.
I’ll give them a try on my Hybrid...
Johnkn
MD
Neither of those bother me much. I’m a 99% pavement driver, few adventures on the weekends. No real snow here either.
Let us know your impressions, I’ll give them a try this Fall on my Hybrid....
Check these out Tire Rack
HANKOOK KINERGY PT
  • ,Size:
    225/65R17
  • Service Description:
    102H
  • Load Range:
    SL
  • Eco:
    Kontrol Technology
  • UTQG:
    860 A A
  • Max Load:
    1,874 lbs
  • Max Inflation Pressure:
    51 psi
  • Tread Depth:
    11.3/32"
  • Tire Weight:
    26 lbs
  • Rim Width Range:
    6-8"
  • Measured Rim Width:
    6.5"
  • Section Width:
    9.4"
  • Tread Width:
    7.1"
  • Overall Diameter:
    28.4"
  • Revolutions Per Mile:
    711p
Johnkn
MD
HANKOOK KINERGY PT
  • ,Size:
    225/65R17
    102H
  • Load Range:
    SL
  • Eco:
    Kontrol Technology
  • UTQG:
    860 A A
  • Max Load:
    1,874 lbs
    51 psi
  • Tread Depth:
    11.3/32"
  • Tire Weight:
    26 lbs
  • Rim Width Range:
    6-8"
    6.5"
  • Section Width:
    9.4"
  • Tread Width:
    7.1"
  • Overall Diameter:
    28.4"
    711p
Those are standard touring tires, my experience is that Hankooks are some of the worst.....
Most tires are in the worst category, I believe the front wheel drive causes excessive wear due to uneven weight distribution. I have to rotate my tires on my crv every 4-5k miles or I will get excessive tire noise at around 6k. I saw the UTQG of 860 A A and 11+/32 tread depth and maybe going to 235's might satisfy All Terrain status along with being 24-26lbs. They probably would have to be rotated often, I suspect. I have 5500 miles on my lariat which has the OEM Michelin 8-9/32" tread. So it's time to check tire wear on it!🤞
Pacman
Pacman
Asheville, NC
‘06 Ranger
Just checked those out—they look PERFECT! You may have just changed my mind.👍
JimmyH
Jimmy
Glad I could help! If you do, please reply with some pictures. Thanks.
Scupking
CT
2025 Ford Maverick XLT Hybrid
Wow I have added those to my list when I get new tires. 28lbs and 3 peak!
Bobinmi
Mr me.
SE Michigan
walking and talking
Any side view of the entire truck with the 235's installed? thanks!
Pacman
Pacman
Asheville, NC
‘06 Ranger
Well in a turn of events I went Nokian Outpost APT 225/65/17. In the end they were about $150 less and seem to have good reviews. Not mounted yet.
Be sure to post pics when you get them mounted!
