Hybrid towing 1860 lb vintage camper
JoeTime
XL hybrid with factory hitch. 7 to 4 pin connector. 1860 lb trailer. Just girlfriend and I, we pack light. Am I pushing it? Personally, I think not. Just towed it home.
If you weighed it after you loaded it and it was 2000 lb or under, you're not pushing it. The posted weight load is 2000 lbs.
Packer Bill
South Dakota
Under ideal conditions, this might be true. However if hills, mountains and/or wind are present, being close to 2000 pounds will shorten the life of transmission.
MavDave
Houston
2022 XLT
The suggested max load rating takes all this into account. Ford would never publish a max rating for a vehicle they weren't 100% sure the vehicle could do in any terrain. Well... with the exception of maybe extremely rugged terrain, like mud and deep ruts. In which you don't need any added weight to break most everything. Ask me how I know that one.
JoeTime
Don't you think Ford considered that fact when they established the tow limit at 2000 lbs?
Dudley
Doug
Indiana
2003 Grand Cherokee
Fords 2022 Towing guide says "Frontal Area is the total area in square feet that a moving vehicle and trailer exposes to air resistance. The chart shows the maximum trailer frontal area that must be considered for a vehicle/trailer combination. Exceeding these limitations may significantly reduce the performance of your towing vehicle."
For a Maverick they says 20 square feet w/o towing pkg. 40 square feet w/ towing pkg.
I would suggest following this even though they don't say it will void warranty because this might be "implied" in the words "significantly reduce".
https://www.fleet.ford.com/content/...rd_RVandTrailerTowingGuide_Fleet_r9_Jan13.pdf
JoeTime
If I were to tow something that I didn't consider aerodynamically suitably constructed, then I would use caution. Thanks.
GPSMan
Many
Ford Maverick Hybrid towing 1860 lb vintage camper 3804B68A-82B4-4C0B-ACA1-1E94B360FA01
Ford Maverick Hybrid towing 1860 lb vintage camper CDEC4A9D-BE85-457E-849D-3934520D63BA
Frontal area not as bad as most people think. This compact trailer is just over 6 feet wide, the factory mirrors were fine. The height sticking up above the cab, not too great and rounded.
Was able to test drive a friend's while I shop around for what to consider buying. I would keep it 60 MPH and under with something like this.
JimParker256
Cedar Park, TX
When I read the Ford Towing Guide, I wonder if they mean "flat plate equivalent" when they say "frontal area?" Because towing a slab-sided, vertical front and back wall "box" would have a LOT more wind resistance than a teardrop-shaped camper, for instance. The airfoil shape has less than 1/4 the wind resistance of the "cube"... I think towing a large-ish teardrop camper behind a Maverick would be pretty sweet camping solution! (Of course, I already have a small motorhome that is capable of towing the Maverick Hybrid, so I'll be doing this "backward"... LOL)
GPSMan
Many
Jim- may I call you Jim? (lol). 😄
Wish we lived closer. I think we are kindred souls. Would be fun to experiment with stuff like differences between trailers, modes, accessories, etc.
