Hybrid ICE Wear and Tear
docsmith1511
Cumming Georgia
Mav XLT LUX velocity blue
Hi Guys. Finally decided to register because I have a question.
My understanding is that the ICE does not kick in until x mph. I don't know the exact speed but when it does kick in, let's say rpm starts above 1500 i guess and on a cold start with the all the oil still at the bottom, doesn't that cause major wear and tear on the engine?
Hoping you guys could explain because I have no idea how it works.
I drive a 2009 Ford escape hybrid, the ice kicks in upon start and will only stop when the engine has reached its operating temperature regardless of anything else. Once the engine temp gets to where it needs to be it will then cycle on and off, ICE to electric. Hope this helps
XLTLUXA51
Ezra
Hardwick Vermont
Ninja 650r, Suzuki SX4, Buell blast 500
I’m not sure about the maverick but I’ve owned multiple Prius hybrids and when it’s cold out (honestly most of the time) the engine will kick in in the beginning and run for the first 5 minutes straight. The battery would be really inefficient at making heat for the car as well so if you have the heat turned up chances are the engine will be running. All that said I’d say that the hybrid aspect of the truck “knows” how to maintain itself pretty well. if you treat it like a normal vehicle it should be fine.
pndwind
Heart of Dixie
F450 Amb
Ye have little faith. My Hybrid is 14 years old, over 150,000k miles, with the original battery.
Dang I wish I could get by driving 10,000 miles a year.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I don't have a clue how hybrids work, but I know Ford and Toyota are the industry leaders in hybrid tech. and this is Fords' fourth generation of hybrid, so I'm just not worried about any sort of oil circulation or ICE wear problems. I'm pretty confident that I'll get as much wear and use out of a new Maverick hybrid as I would any other car.
pndwind
Heart of Dixie
F450 Amb
Plenty of people with the same car as mine with over 200-300k miles. I'm very happy that I don't have to drive a lot thank you very much.
No sarcasm, I really do wish I could get by only driving 10k a year.
WannaMav
Hawaii
2022 Maverick hybrid
Heh. At this stage of life if I put on more than 1000 miles in a year I consider that an upward aberration from the norm.
Currently tooling around in a '94 with 55k miles on it. Used vehicle, original owner racked up the bulk of those miles.
pndwind
Heart of Dixie
F450 Amb
Unfortunately I do that in a week or less sometimes.
BlackXL
Cliff
Black Hills, South Dakota
2 F-350, 2 F-250, 4 escape, mustang, bronco
Hybrids use an electric pump for the oil, which pushes it into the engine before it starts, and keeps it moving, otherwise all the oil would settle in the pan whenever the ICE shuts down.
Source?
Dbarr
DB
SC
Fiat 500c, Dodge Grandkidsvan, Maverick
I’ve owned 2 hybrids… just drive it
Fotomoto
Doug
South Texas
Sienna hybrid, Lincoln Corsair GT
As FBOV said, the 300+ volt HV battery spin starts the ICE. And here's a little more: first, it spins it much faster than a 12v crank-start could ever dream of doing, without fuel/spark. This gets the mechanical oil pump spinning and building pressure, then the fuel/spark are added in. If the HV battery has sufficient power/SOC (state of charge), the ICE will "idle" and warmup a bit before being blended in with EV side.
Interesting fact: the computer can also spin the ICE without fuel as a way to burn off excess electricity when the HV battery is full (going down a long mountain road for example). It often sounds the same as running.
I am thinking when I get below 2500 miles a year I'll join the "car club" (3-4 neighbors who share a car).
