How To: Sync 3/4 swap for non Sync 3 XL/XLT
New2AZ
Scottsdale, AZ
2019 Civic EX Hatchback
I wish some of you guys lived around me. Bought an APIM (preprogrammed to my VIN) and was about 98% of the way having that sucker hooked up, but got stuck on the last couple steps. Asked my dealership if they could finish the job so I don't break anything, but unsurprisingly they could not. So if anyone has FORSCAN and wants a 2020 F-150 SYNC 3 APIM, DM me. Otherwise I have a $450 paperweight.
mesajoejoe
Chicago
Can you share the code you used?
Here are the items that are different from what's posted on page 1
727-01-01 B02B 14F2 0011
727-02-01 1344
727-04-02 5300 0000 0087
727-04-03 0000 0000 0035
727-04-04 0000 0000 0036
727-04-05 0000 0000 0037
727-06-01 0156 0001 7603
727-06-02 0001 8600 02BF
727-06-03 2600 0236 0095
727-08-01 4041 4243 4481
727-08-02 4506 4748 091B
727-08-03 4A4B 0C4D 4E75
727-08-04 0F50 5112 534F
727-08-05 5415 5657 1869
727-08-06 595A 1B5C 5DC3
Deleted member 15499
Guest
727-02-01 1344
I disabled xm in this config because I'm not going to pay for it, the rest was kind of trial and error to get things working without any DTCs
Bob The Builder
Butch
Vermont
I would have had a nervous breakdown by the third step. :ROFLMAO:
mesajoejoe
Chicago
GPS was WONKY for about 8 minutes then figured itself out. Carplay doesn't show the navigation stuff next to the song in the 12" digital cluster using Apple Maps or Google Maps, but Android Auto does. If anyone else is looking to do this, make sure you don't mess up the wiring and have to shorten any, things get tight with shorter length. The black plastic of the HVAC shroud or whatever is SHARP, cut up my knuckles good. There are very few config options now in the infotainment, especially under "Vehicle Settings", I wonder if we can get some of those back. I cannot get Fordpass get to reconnected to my phone, errors out during Activate Vehicle. I've reset the app on my phone, and in the truck several times. Hopefully I can get it figured out before winter! Can confirm the backup camera framerate is higher, much smoother and doesn't skip like it used to. Comes on instantly when switching into reverse, used to take a few seconds sometimes. Can't think of anything else... maybe add some foam buffer or felt between the APIM and the metal brackets to reduce any future vibration noise.
unclerunkle
Aaron
Wisconsin
Grand Marquis
Anyone have any luck getting vehicle settings back? Sounds like those would be important.
Guest
Has anyone used this to get Sync3 working?
I'm helping a friend install Sync3 in his XL, I have Sync4 working in my XL but he want's to go Sync3 for the updates.
We bought a Sync3 Gen 4 APIM on ebay, plugged it in and just got a black screen, I was able to communicate with it with Forscan so I know the wiring was good. We returned that one for another, with the same issue.
Finally looked at Cyanlabs and it looks like you need a specific model to work with MY20+ screens?
I'm hoping someone has done Sync3 with success and let me know what unit you bought.
mesajoejoe
Chicago
I still believe there is harness work to be done for Sync3. From Page 1:
Sync 3 will not have wireless carplay/android functionality and will require additional wiring
zackmd1
Zack
Maryland
1970 Mustang 429BB / 2019 Tesla Model 3
Sync 3 requires pins 53/54 to be connected in order to boot. This is likely why you are getting a black screen but can communicate with it over forscan. HS CAN can be tapped into from the OBD port. Pinout is in the OP.
Guest
I do have those wired up! But still the same thing unfortunately
zackmd1
Zack
Maryland
It sounds like it is still a wiring issue. I would double check everything.
Telemachus
Jason
XL EB (sold), XLT Hybrid
Will a non-nav sync 4 module work?
dalola
Retired
SE Ohio 🇺🇸
Maybe those with experience in this can help me out.
I swapped in a Nav enabled APIM for my Lariat Lux, Sync 3 gen 4, should be direct plug and play, as I understand.
Everything works EXCEPT the nav gps tracking. The map initially loads to a town in CO (probably where it was flashed/tested), and after a few minutes, I get the little "GPS" in a red circle with a line through it, similar to what happens when you drop satellite communication in heavy forest or tunnel.
Thoughts?
Telemachus
Jason
Yes it will! No real purpose to get a nav based one because it's subscription based
Agreed. Sync 3 no reason not to. OP mentioned only getting the nav version.
Carplay GPS works fine?
