I wanted to post an update. I’ve gotten my SYNC 4 asbuilt the way I want it. Everything works except FordPass. I swapped the SYNC 3 APIM back in to reactivate FordPass. After putting back the SYNC 4 APIM it seems that FordPass is not able to connect. I'm waiting for @mordfaverick to try with his 22 Lariat. The only difference in our Lariats is his has the 4G modem with hotspot and mine has the modem without hotspot. Logically this shouldn't matter because every Maverick has FordPass. But I think the OP had an early 22MY that had the 4G hotspot modem.
This asbuilt has a few changes from the OP:
Changed the first block 7-1-1 XXXX from the OP to fix the volume issue I was having. I think this is because the OP used a non-maverick ACM in his build.
Removed all HVAC popups and menus in the SYNC 4 screen because I swapped my HVAC panel to one with the temperature displays.
Enabled ambient lighting
The wireless CarPlay works great. I've had no connection issues. I was using SYNC 3 with the carabc wireless CarPlay adapter. It had occasional hiccups. For now it's worth it to me to keep SYNC 4 installed and hope to find a fix for FordPass.
