Gray Goose
RG
Wissota
I'm usually hauling stuff for DIY projects. First thing I do when loading is grab a pair of gloves from the storage area under the back seat. I often forget to press the unlock button twice to unlock all doors.
There's a section in the keyless entry settings that describes how to switch from two-stage unlock to single stage unlock which unlocks all 4 doors with pushing the button just once. (Page 79 on the 2024 manual)
Hold both lock and unlock buttons for 4 seconds. Also described on this page: https://www.fordservicecontent.com/...&div=l&vFilteringEnabled=False&buildtype=web#
Ringo
AR
1953 MGTD, 1953 F100, 2022 Maverick
Thanks for posting this! since it appears easy to reverse this I will try it this morning.
not null
"Upstate" NY
Hybrid Mav
Thank you! I did not know this was a feature. Works on 23 XLT w/LUX
The menu option also works on non-Lux non-keyless entry.
1 press driver door, 2 presses all doors. Or 1 press all doors.
The fob ability to change the option doesn't - must be keyless system.
Shelbyv8
JD
Mine works on a 2023 XL with CP 360.
Ozarkbeard
User preference, but I prefer 1 press unlocks all. Otherwise, I found myself unlocking the driver door only, but when I would go to pick up someone, they would always be yanking on the door handle to get in.
I live in a rural very low-crime area and find all this locking/unlocking bullshit annoying af.
SubtlySeismic
Don
Houston, TX
2024 Maverick XLT Tremor
Thank you for sharing this hack! I reprogrammed immediately. My family rides with me a lot of the time and the kids always try to rip the handle off after first click :)
I'm more concerned with the Autounlock I've left on so far.
Like at gas station, habit was take key but driver door stayed unlocked since I'm right on that side, same with truck.
Except now the other doors are unlocked. No problem yet, but not a good habit to keep with all doors unlocked in several situations.
I guess I could sit around and listen for music for 10 min while on phone, except music stops earlier ...
Already annoying enough for backseat passengers to double-tug the handle to get out before I can hit the unlock button.
WHAT IS AUTOUNLOCK
Autounlock is a feature that centrally unlocks the vehicle doors when your vehicle comes to a stop and you open the driver door.
AUTOUNLOCK REQUIREMENTS
Autounlock unlocks all the doors after:
  1. The vehicle speed exceeds 12 mph (20 km/h).
  1. Your vehicle comes to a stop.
  1. You open the driver door.
Note: Autounlock operates for only 10 minutes after the ignition is switched off.
SWITCHING AUTOUNLOCK ON AND OFF
Using the information display controls on the steering wheel, select Settings.
  1. Select Vehicle Settings.
  1. Switch Autounlock on or off.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
🤓 You can actually set that up under settings. Easy Peezy. o_O
BennyMav
Ben
Orange, VA
2024 Ford Maverick
Sweet! Thank you. Worked on my 24 XLT.
Frank
Kansas City
2024 Maverick Atlas Blue Lariat FX4 4K
Thank for posting this info Gray Goose! It works on my 2024 Maverick and my wife's 2022 Bronco Sport. And this is easy to disable if needed, for those wondering.
