Rivers90
Ben
XLT Tremor, Miata
I used the this post to plan what I needed. https://www.mavericktruckclub.com/forum/threads/1st-oil-change-on-the-tremor-today.29555/ Thank you Dave
What I used for the oil change
13 and 15 mm sockets and ratchets
T30 Star Bit Socket (torx socket)
Oil filter wrench
Funnel
Motorcraft - Oil Filter (FL910S) for 2024 and earlier The 2025 needs a FL-2127
5w-30 synthetic motor oil
Oil drain pan
Aluminum foil
Painters tape
The height of the truck let me change the oil with out using ramps or needing a jack.
removed the Four - T30 TORX fasteners
Removed the six -13 mm bolts
The skid plate is heaver than you think it will be and awkwardly large, be ready to hold it.
The oil filter has some of the plastic under bumper under it so I taped the Aluminum foil to catch the oil that will poor out of the filter when you remove it.
I drained the oil and changed the filter. Installed new filter and new oil.
Checked the level of the oil, and checked it again after running the truck. Checked for leaks then put the skid plate back on.
Here are the photos.
Ford Maverick How To: Oil Change on Tremor Maverick oil
The oil
Ford Maverick How To: Oil Change on Tremor Maverick tools
The 13 and 15 mm and the T30
Ford Maverick How To: Oil Change on Tremor Maverick star skid
T30 TORX
Ford Maverick How To: Oil Change on Tremor Maverick bolts skid
The 6 bolts
Ford Maverick How To: Oil Change on Tremor Maverick skid
The skid, was thicker than I thought it would be. Nice
Ford Maverick How To: Oil Change on Tremor Maverick undersid
Oil filter top left partly hidden under the plastic. But has plenty of room to reach it. Drain plug is on the back side of the oil pan, you can just see the edge of it.
Ford Maverick How To: Oil Change on Tremor Maverick green oil
The factory oil looks like alien blood. But you do need good light or else it just looks dark.
Ford Maverick How To: Oil Change on Tremor Maverick drain plu
Oil drain plug, use the 15mm to remove.
Ford Maverick How To: Oil Change on Tremor Maverick old oil filter
old oil filter
Ford Maverick How To: Oil Change on Tremor Maverick funnle
new oil going in
Way more photos then you need but I wanted to cover it all and help others with their trucks as much as I can.
Next person to do an oil change can make a video.
Rivers90
Rivers90
Ben
XLT Tremor, Miata
One more photo showing the foil taped to the bumper.
Ford Maverick How To: Oil Change on Tremor Maverick foil
More oil will come from the oil filter than you think and the bumper has lots of places for it to get stuck. This made cleanup easier.
Non-Tremor Mavericks don't need this, their bumper is different the oil filter does not drip on the bumper edge.
bautek_mn
Minnesota
WRX Sport Wagon, Future Maverick
Coming from Subarus where you always replace the drain plug crush washer, is it recommended to do the same with that green gasket on the Maverick?
dalola
Retired
SE Ohio 🇺🇸
My FX4 has a second removable (plastic) piece between the bumper facia & the skid plate, comes off with a few more T30 screws. Not sure what non-FX4 Mav's use.
Also, the Tremor skid plate appears to be the same as my FX4. I was also surprised how heavy it was. The rear two bolt locations are slotted, so you don't need to fully remove them. It also helps hold/guide it back on.
Rivers90
Rivers90
Ben
XLT Tremor, Miata
I went by a post on the bronco sport form where they say to reuse it if it is not cracked.
https://www.broncosportforum.com/forum/threads/oil-drain-plug-washer.6626/#post-115701
The bronco sport badlands has the same 2.0 as the Maverick. Non-badlands BS have a different engine.
It is cheep so you may as well change it, just be sure the old one is gone and not stuck to the pan, you don't want to stack them old on new.
I reused it.
From the post on the Bronco Sport form.
" Checked in at the dealership. For anyone wondering, the drain plug has a gasket on it and is meant to be reused. They said that you can keep reusing it as long as it is not cracked/damaged. "
Rivers90
Rivers90
Ben
XLT Tremor, Miata
dalola
Retired
SE Ohio 🇺🇸
fossil
ernie
ohio
I'm with you on this, the drain plug looks questionable.
EM33
NJ
68 Datsun L521 / 69 Datsun SRL311
dalola
Retired
SE Ohio 🇺🇸
Mike Douglas
Bay Area, CA
Outback
This forum is really terrific. Thanks to the OP, Dave and to Rivers90 for all the pics. I was concerned about getting the skid plate back in solo, but it's smaller than I thought, roughly 2'x3', maybe, and the back screws holes are slotted, as another poster noted, so that helps.
I had 2600 miles on my truck. Too soon? My Dad used to change his after 1000 miles on a new car, like 50 years ago.
So that was all good. Now for the concerning item. 🤨 While tightening the new oil filter in place, this item fell out. I have no idea where it came from. I think it may have been loose just sitting i
On the plastic cover that's in front of the skid plate.
Does anyone recognize this?
It's threaded on one end, so kind of adjustable.
Appreciate anyone's thoughts.
Thank you all again.
Ford Maverick How To: Oil Change on Tremor Maverick IMG_20230512_152622806_HDR
Ford Maverick How To: Oil Change on Tremor Maverick IMG_20230512_152605309_HDR
Ford Maverick How To: Oil Change on Tremor Maverick IMG_20230512_152557148_HDR
Rivers90
Rivers90
Ben
XLT Tremor, Miata
Does anyone have the part number for the green gasket?
Montana
The only difference I can see is the plastic "scoop" that is snapped on to the FX4 plate, where yours just has the open hole, back by the two slotted mounting points.
So the Tremor only has the rear "skid plate" unlike the FX4 that has a two piece? Because if it's a two piece, be careful only removing the back portion of that underbody carriage. If it's like the FX4, it's actually designed to have both pieces removed together. Don't just uninstall the rear one unless you want to replace a bunch of those cheap "not quite bolt" thread things they go into.
Why? Because those crappy screw stop things they use will break easily. Not only do they rust, but they are flimsy as hell. They only use them on the spots where the "skid plates" meet. From the pics, it looks like the Tremor's don't have them but just wanted to confirm. To any potential FX4 owners reading this: Just go around the edges and take both off at the same time. Save yourself the heartache. FORD should have never used those crappy metal screw housings.
Looks like a hood stop or something similar. You might want to start your own thread to get more attention to it. Title it something like "help identifying part that fell off and where it came from".
Interesting they extended the plastic bumper so far instead of just using the dual piece FX4 style skid plate. Actually, it's a good thing (if you read my previous comment about the dual piece).
You can also buy a sort of "splint" funnel to wrap around. They are flexible and can be used as either a guide or a layer like you are using the foil for.
Here is an example of one
I forget which one I have specifically, but no need for it on the FX4 with both skid plates removed.
I just replaced the fuel filters in a 2019 Ram 2500 and they have a little tube to direct the fuel once you vent the front filter in the engine bay - right on top of the front dif lol. Like, if you are going to design a tube vent system to bleed with... why TF would you not direct the tube away from leaking on top of everything below it lol. Never ceases to amaze me. So many vehicle just have these terrible designs to leak fluids all over parts below them. Actually, the transmission level plug on the Mavericks is one of them too.
