- First Name
- Ben
- Jul 17, 2021
- California
- XLT Tremor, Miata
- Engine
- 2.0L EcoBoost
I used the this post to plan what I needed. https://www.mavericktruckclub.com/forum/threads/1st-oil-change-on-the-tremor-today.29555/ Thank you Dave
What I used for the oil change
13 and 15 mm sockets and ratchets
T30 Star Bit Socket (torx socket)
Oil filter wrench
Funnel
Motorcraft - Oil Filter (FL910S) for 2024 and earlier The 2025 needs a FL-2127
5w-30 synthetic motor oil
Oil drain pan
Aluminum foil
Painters tape
The height of the truck let me change the oil with out using ramps or needing a jack.
removed the Four - T30 TORX fasteners
Removed the six -13 mm bolts
The skid plate is heaver than you think it will be and awkwardly large, be ready to hold it.
The oil filter has some of the plastic under bumper under it so I taped the Aluminum foil to catch the oil that will poor out of the filter when you remove it.
I drained the oil and changed the filter. Installed new filter and new oil.
Checked the level of the oil, and checked it again after running the truck. Checked for leaks then put the skid plate back on.
Here are the photos.
The oil
The 13 and 15 mm and the T30
T30 TORX
The 6 bolts
The skid, was thicker than I thought it would be. Nice
Oil filter top left partly hidden under the plastic. But has plenty of room to reach it. Drain plug is on the back side of the oil pan, you can just see the edge of it.
The factory oil looks like alien blood. But you do need good light or else it just looks dark.
Oil drain plug, use the 15mm to remove.
old oil filter
new oil going in
Way more photos then you need but I wanted to cover it all and help others with their trucks as much as I can.
Next person to do an oil change can make a video.
Oil filter wrench
Funnel
Oil drain pan
Aluminum foil
Painters tape
The oil
T30 TORX
The 6 bolts
old oil filter
new oil going in
