How to disable the seatbelt chime 2024 Tremor Maverick
Reecezupcic
Reece
Bensalem PA
2024 maverick
Does the option of disabling the seatbelt chime still exist with the new 2024 ford Maverick Tremor?
hurrah
Richard
Hartville, MO 65667
2019 Ford Ranger 2012 Ford F250 6.7 2015 Ford XL
I'm on my way out to try this! I've gone thru the manual sequence half a dozen times over the last year with 0 success and finally spent $5 and purchased little clips that fit in the seat belt buckle! I actually use my seat belts when I'm going somewhere but around the Ranch when I'm in and out half a dozen times and not even on a public highway they are a pain in the ass and I've always been able to disable the chime on my other Ford trucks!
Ozarkbeard
Thanks.
I've gotten the driver's side done but haven't been able to successfully do the front passenger seat. Did you have a helper sit in the passenger seat while you did this, or did you do it alone?
Ozarkbeard
I figured you did, since you mentioned it.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Thanks.
I just put a big battery charger or case of paper in the passenger seat.
Justin says...
Justin
NC
'22 Ranger XLT
What about getting rid of the seatbelt popup at startup? Is that possible?
Ozarkbeard
Thanks. I'll try that!
If you're referring to the seating chart & green checkboxes nag box that shows up on the instrument cluster and you have to hit OK to dismiss, the answer is no - at least not that I'm aware of. :(
Bent Wheel
Ed
New york
Toyota
I have a 2024 Hybrid and followed your direction. It does not work. I followed the manual and it doesn’t work. I get a screen that alternates between “seatbelts” and “press brake to start”. Any idea?
