How to keep “My View” window open in Instrument Cluster?
MavMeister25
South USA
‘25 Ford Maverick XL
For the 2025 models…
Is there a way to keep your preferred My View window open in the instrument cluster even after you’ve turned truck off and restarted the vehicle? I don’t like having to bring up the “this trip” or “EV coach” every time I start the vehicle. The infotainment screen seems to save your last used setup. So it seems like the instrument cluster behind wheel should be able to do the same. My previous vehicles have all had this feature. Anybody know?
thesilverstig
Otto
Detroit
2025 Maverick XL Hybrid AWD
I haven't figured this out either. Feels kinda pointless to call it my view then not default to it. I still don't like that I have to press one button to see any info other than a speedo.
commadorebob
Sounds like a candidate for Forscan.
vandeda2024
US
2025 XL Hybrid, AWD, 4K
Agreed. I noticed that too. Would love for it to come up by default.
MavMeister25
MavMeister25
South USA
They could easily fix this issue with a software update. I heard on another Ford F150 forum that the same thing happened—there was a software update shortly after the release of new model. I guess people were complaining.
PGAJayhawk
Seth
Kansas
2025 Maverick
I'm hoping they fix this with an update. I agree that it is pointless to offer it and then make you jump through hoops to access it everytime you drive the truck.
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
If Ford applies a software fix for this, I hope they take the opportunity to retain the last 'drive mode' instead of resetting every time the truck is started.
I won't hold my breath because users have complained about that since the truck first came out.
thesilverstig
Otto
Detroit
I believe the current one button press is required by the epa. The vehicle must default to the mode it's tested in so that standards are consistent with end users. To create an exaggerated example, lets say eco mode got 10mpg better than normal mode, the epa couldn't count that eco mode unless it was the default the vehicle turns on to.
my Bronco with sync4 will prompt you to hit OK to resume last drive mode, but it is not on the driver's panel for very long at all - maybe 5 seconds ? - and it's easy to miss, then it loads normal drive mode. doesn't the MY25 Maverick do this same thing?
___
however, in regards to the issue mentioned in the first post, it does NOT do that. any screen picked in MyView does stay there until you change it. that seems like a bug for a MY25 Maverick to not stay on the last screen used in MyView.
thesilverstig
Otto
Detroit
Mine certainly does. I agree that it's a pretty quick window though doesn't seem to stick around nearly as long as the damn seatbelt reminder.
GmanGM
Garry
Baltimore
Dakota
___
So far I have seen that prompt to stay in eco mode only once and it flashed by so fast that I missed it- That misses the point anyway because it still would require you to 'do something every time' - now if it flashed by asking if you want to return to normal or some other mode and stayed in eco if you don't do anything-that would work!
MavMeister25
MavMeister25
South USA
Yea I get the justification for keeping drive mode resetting to normal. I’m just talking about keeping the MyView always on the one you last had showing.
if you remote start, that prompt might not be shown at all. that's what it seems like on my Bronco at least. it's in normal mode almost all the time, but when we had snow on the ground 3 weeks straight, my wife did use slippery mode the whole time and it is annoying if you miss it and have to re-select.
btw delete your other post. there is no politics allowed in this forum, which is a very good thing, and they're doing a little bit of badly-needed crackdown so just ... don't.
