how many pounds lbs can the tailgate support?
LSchicago
Lloyd
IL
DinoLord
Brandon
Conroe, Tejas
24 XL EB AWD
It's just geometry. It's near impossible to *not* have weight distribution into the bed when the tailgate is in the mid position. Therefore 400 direct on flat tailgate or 500 distributed between angled tailgate and the bed.
  • Like
Reactions: Ven
Timothyd
Absolutely, the major weight stands on the bed.:p
Of course, the big 300lb ramp at the dealership rested on the tailgate along, for a moment, with most of the weight of the 480lb bike and the 3 guys pushing it onto the bed. The tailgate passed the test.
  • Like
Reactions: Ven
m5040
CT
Cummins Dodge
The cables are stronger then the thin sheet metal. The weight limits are to keep you from bending the metal gate that is why it specifies evenly distributed. The distribution doesn't change the stress on the cables.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
  • Like
Reactions: Ven
RicksMaverick
Rick
Westfield, IN
Rapid Red 2022 Lariat Lux 1$tED 4k AWD
That's what I an concerning, We need climb into/out the bed over the tailgate, sometimes even jump down, I worry about whether the thin cable can support it or not:p
The cable will hold way more than you think, the tailgate would probably bend/ buckle before the cable would. Look up wire rope strength and look at some of the charts. Stick with the manual!
  • Like
Reactions: Ven
vinnymac
Vince
Yes, though TBH I’m getting old enough to want a step stool of some kind to save my knees getting back down. :oops:
Not sure how the people with full size trucks do it.
HarborFreight has a tailgate ladder 40.00$
  • Like
Reactions: Ven
Is it safe to stand or put heavy stuff on the tailgate?
There is a 400 lb limit, but someone posted a picture of his golf cart loaded in his maverick. He had to let the air out of his front tires so he could get his carts rear tire center line on the back 2" of his tailgate. If I remember correctly he drove it home about 700 miles. Would have to find thread and verify distance.
Found it:
Look What I Can Do! Hauled 700 lbs golf cart 200 miles
