A couple of days ago, I was running errands, everything great, as usual. Then, I got into the 2026 Maverick XLT, and I had no electronics. The big screen was black. Console screens were OK. Turned it off and back on a couple of times - no change. So I decided to drive on to next stop. Put it in reverse, had backup camera - but none of the usual guidance - just a camera of what was behind me. Parked at next stop, went in, came out, cranked the truck - everything working fine!
Since then, I had one event where, on startup, things hesitated while the screen said couldn't find the key. Then that went away immediately and everything was OK.
Before that, I had an event where I went to get in the truck and it wouldn't recognize my touch and open up. Tried several times. Then just stood there for a few minutes pondering this. Tried again and it opened up.
On another occasion, got in truck, cranked up, went to put it in reverse, and the gear selector would not turn. Tried rotating the steering wheel a bit, and then it let me put it in gear.
I also discovered by accident that if you open the door to lock the truck, and don't let go of the doorhandle while pushing the lock button, the next time you try to get in it won't let you. I went around to the passenger door to get the truck to unlock.
So... Is this normal stuff? Or do I have serious problems developing in my 2 month old truck?
