Hood will not unlock.
PapaRed
Will
Glendale, AZ
2023 Lariat Hybrid, 2002 Saturn L200
As Donald said, I had SWMBO pull the handle to the second pull while I held the hook partly closed. The second latch opened, the hood was raised, and the struts removed.
Operational check with struts removed, hood operates as designed. THANKS to everyone who offered help!!
Darrel R. Ferguson
Darrel
Monroe WA.
rancharos mustangs explores chevy
My truck was inconsistent - and then I installed the two hood struts. Now the hood won't open. If I can figure out how to get it open, I will disconnect both struts and check. I like the struts (not the hold open rod) but if that is causing the issue, i'll take the struts off.
i also added the struts. they pull down slightly so the latch might not fully release. have someone lift on the hood when you pull the release. should not take much.
Azmig88
Ted
2022 Ford Maverick 2.0 Lariat
As I understand it, here’s the issue
Without struts:
You pull once, the hood pops up a little, you pull the 2nd time and it pops the 2nd catch loose.
With struts:
After the first pull on the lever, the struts are pushing the hood up enough so that the second pull doesn’t disengage the catch.
I hope that was clear enough to make sense.?.?
I really liked them (when they worked)
Fastbackjon
Jon
Iowa
2022 Maverick XLT 2.0, 18 Flex, 20 Edge, 21 Escape
Fyi- after I installed a set of hood struts I adjusted the hood bumpers on each end. It put a little extra tension on the hood but kept it plum with the gaps and still level body surfaces. No issue opening my hood. And in fact after reading about the hood spring post- I may go ahead and get one of those to install. I like the hood struts personally- great to not have a prop rod in the way.
Azmig88
Ted
I don’t like the prop rod either.
Let us know when you have more info about the hood spring post idea.
Thank you
Azmig88
Ted
Bigbill27
Kentucky
2012 focus, 2023 Maverick Hybrid
Old Man
Nebraska
2023 Lariat
Mine just did it after readjusting hood after struct install. Didn't have anyone to hold hood down while pulling release lever so I pulled the lever completely back and put a piece of wood under it to keep open. Then went to the hood and pressed down slightly then pulled up. It opened. Adjusted the hood stops slightly to see if that helps.
Going to ask the service department Monday how they open the hood if it stops like that and pulling the lever doesn't work.
Goose20
dave
ohio
maverick
According to the Owners' Manual, to release the hood, pull the lever, allow it to completely retract, hen pull again. On my recently acquired '23 Lariat, the hood unlocks on the first handle pull, but nothing happens on the second pull. Hood pops open, but does not release. Any suggestions?
Same problem goin to dealer in the AM.....for about the 10th time...
Mr Pibb
Vegas
2024 Lariat
The cable can detach from the back and just has to be reseated in the release handle. It can happen if you used the hood struts.
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
To those who have removed the struts due to hood opening issues, which brand of hood struts did you have?
I have had the Redline Tuning struts for nearly 3 years now with no issues whatsoever.
