- Banned
- #46
Why would you say these things? I'm not following your logic here.This is great advice in theory, but in many situations impractical. Most of the time when I "need" heat it is because the windshield is frozen/snow covered/foggy.
All this time spent idling and warming is the first time I have seen where an argument for a larger battery makes more sense. I am spending a lot more time above 60% charge these days. BUT that just means that I can spend more time coasting though! Still have not seen below 40MPG despite changing tires and weather. I am impressed.
A) Using the blower vents on a cold engine with temperature set to a high number is like trying to heat your oven with the door open slightly. It will heat up eventually, but more slowly.
B) Has nothing to do with battery size. Heat is coming from burning gasoline, and gasoline only, unless you evoke the mythical "booster heater" that requires gasoline and electricity at the same time (can't run on battery alone) and rarely comes on because it's inefficient and special conditions must be met.
