Got the recall for the trailer MODULE, Remedy not AVAILABLE to Q2
jbrown9889
Justin
Clover, SC 29710
2024 Ford Mavericks XL
Ford Maverick Got the recall for the trailer MODULE, Remedy not AVAILABLE to Q2 IMG_0686
jbrown9889
jbrown9889
Justin
Clover, SC 29710
Ford Maverick Got the recall for the trailer MODULE, Remedy not AVAILABLE to Q2 IMG_0687
Packer Bill
South Dakota
This not surprising. Thanks for the update.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
What's not entirely clear in this recall is whether it's just for 4k tow units with brake controllers or all Mavericks equipped with 4 pin 2k or 4+7 pin systems.
OP the info in your signature indicates you have a FWD EB with the 2k 4 pin base system is that the case? I'm not seeing this with my VIN yet at this point.
jbrown9889
jbrown9889
Justin
Clover, SC 29710
Yes, my is fwd 2 k with 4 pin
Packer Bill
South Dakota
Remedy SOFTWARE IS AVAILABLE TO REPAIR YOUR VEHICLE. FORD MOTOR COMPANY HAS RELEASED SOFTWARE FOR 26C10.
This info contradicts the OP's initial post.. My Ford app also shows the 26C10 recall now.
Based on post #6 it appears to be for both 2K & 4K trucks with a 4 or 7 pin trailer connector 🤷‍♂️
I have a MY22 EB AWD 4K tow, logged into ford and it shows the recall for my vehicle but states a fix is not available until Q2/2026. Guess we'll see if they meet that date or not.
Issue Date
2026-03-18
Campaign
26C10/26V104
Description
On your vehicle it is possible that the trailer module trm may lose communication at vehicle start-up. If a trm loss of communication occurs and a trailer is connected to the vehicle, trailer stop lamps and turn signal indicators will not function. Additionally, for trailers equipped with electronic trailer brakes, the trailer brakes will not function. This loss of communication can occur with-or-without a trailer connected to the vehicle and can only initiate at vehicle start-up. If this occurs, a trailer brake module fault notification will pop-up on the vehicles instrument panel cluster. The vehicle brake and turn signal lamps will continue to operate normally and are not affected by this trm fault. If you do not tow with your vehicle, you may wait for ota deployment for your vehicle remedy.
Safety Risk
This may result in inoperable trailer brake lights, trailer turn signals and trailer braking functions that can reduce a drivers ability to control an attached trailer and make the trailer less visible to other drivers, increasing the risk of a crash.
Remedy
Software is not available. Ford Motor Company is working to provide software for this repair. When the remedy becomes available, Ford Motor Company will notify you via mail to schedule a service appointment with your dealer for repairs to be completed free of charge. The remedy is anticipated to be available in Q2 2026.
Next Steps
Contact your dealer for more information to schedule the free service.
commadorebob
It appears if you get OTA updates, then it is available and will download on its own. If you have an older Maverick, then you will have to wait until Ford rolls it out to dealerships.
Northern
New Jersey
2025 Maverick Lariat
Have a 25 AWD hybrid with 4 pin connector. Had a local dealer that has mobile service complete the trailer wiring and parking module recalls this morning. Took about 20 minutes and the process went well
fordvideoguy
Salina, KS
www.long-mcarthur.com
2022 F-150 Lightning, 2021 Ford Bronco
Both. The abvance notice I read mentions vehicles with Brake Controller, it will affects Braking function as well as brake lights.
gjallen3
Jerry
Arizona
2024 Maverick XLT
When I log into my dashboard from the Ford website the Recall notification is there. However the app on my phone shows 0 recalls. CarFax sent me a notification but nothing from Ford yet. I have a 24 Eco with 2k.
Packer Bill
South Dakota
The software fix is available right now for the 25 and 26 models. However, the fix is not available for the 22-24 models yet.
jbrown9889
jbrown9889
Justin
Clover, SC 29710
Ford Maverick Got the recall for the trailer MODULE, Remedy not AVAILABLE to Q2 IMG_0706
parts are not available right now, what do that mean
