Gas Tank Door
JSB
San Antonio, Texas
2024 Maverick
I have a 2024 Lariat. The manual says there should be a lever in the wheel well that can be used to manually open the door to the gas filler if the button on the cab is not working. This is honestly something I never thought about, but now that I have read about it I am aware that my truck does not seem to have this. Is there some other way to open the gas door if the button malfunctions?
CurtisB
2023 Maverick XLT Hybrid
My button is located on the instument cluster where the headlight/on-off adjustments are. It has a cute little "Gas pump" icon on the button.
First Sergeant
Fruitland Idaho
2023 XLT Hybrid 2014 Toyota 4Runner Limited
Is actually a green tab that you pull on right above the shock.
Clarkdonbran
Like sand through the hourglass these are the days of another green tab post.
ilikebike
2024 Ford Maverick Lariat Hybrid HPR w/ BAP
To be fair, this was a "Where is the green tab?" post and not a "WHAT THE HECK IS THIS GREEN TAB?!?!?!"
Someone read their manual and is learning about their truck! Nature is healing!
Clarkdonbran
True dat! I wasn’t hating, just having some fun. I ask the absolute dumbest questions on here so I can’t talk much!
JSB
San Antonio, Texas
2024 Maverick
Thanks for letting me know where it should be. I re-checked and it is not there!
I'm not sure if this is worth pursuing with Ford.
Ford Maverick Gas Tank Door PXL_20240328_183618520
Bigbill27
Kentucky
2012 focus, 2023 Maverick Hybrid
It may have popped-off and is behind the shroud.
JSB
San Antonio, Texas
2024 Maverick
Yes, I felt behind the cover but it is a pretty tight fit even for a finger. I did not feel anything.
CaptKirk
Kirk
Placerville, CA
Maverick, Explorer, Focus
I can verify that my 2024 Lariat Hybrid has that tab there. That destroys my theory that it is more secure than manual opening gas doors... :-(
CaptKirk
Kirk
Placerville, CA
Wait- you do have a HYBRID that has the button operated gas door, correct?? If so, then yes, pursue. If not, you just manually open the door and no tab is necessary to overide a broken dashboard button.
JSB
San Antonio, Texas
2024 Maverick
Yes, it is a HYBRID with the button-operated gas door.
I will probably wait until it goes in for something else and then have them look at it again. I was actually at a dealership yesterday to pick up a n accessory. I asked the service advisor about it, and he looked and just told me that the manuals are boilerplate and not al models have all features...
Ozarkbeard
NW Ark.
'23 XL CP360
It's supposed to be there and it is not. If it's a new vehicle, you should get it fixed under warranty, before you forget about it. Not having it could leave you stranded if you're on a trip and the 'lectric fuel door opener fails for whatever reason.
Johnkn
MD
22 TRX, Viper, 66 Shelby, 68.5 CJ Mustang, Pantera
OP, you can likely easily fix it yourself in 5 minutes... the cord probably came unclipped and is hanging behind the liner.
The plastic inner wheel well liner is retained by several plastic push pins around the outer lip closest to the outside of the truck. Pop out the pin at the 12 o'clock position and at the 10 o'clock position and you will see where the cord routes to the gas door... just reach in and position it back to where it should clip on (shown in the area you pictured) then pop the pins back in.
Good luck
sprcoop
AZ
2023 XL Hybrid, 66 Mustang Coupe, 2012 Focus DCT
@CaptKirk it is more secure since you need the key to operate that tab.
Page 177 in 2023 manual. Directions to manually operate the hybrid fuel door.
1. Switch the ignition on.
