Garage opener Homelink buttons for sun visor?
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
I’m sorry, can you clarify your modifications? I’m trying to figure out exactly what you did to make it fit properly!
No problem. See the pic where my thumb is holding a small piece of black plastic up against the underneath side of the mount of the visor? I taped that little piece of plastic on there with electrical tape. Doing so filled in the space that was causing the new visor to wobble and be loose. Also I can report after 6 months of usage my visor is still nice and tight. I hope that helps you.
24atlasmaverick
Christopher
Buffalo, NY
2024 maverick XLT, Lux, FX4, AWD, 4K
It does thank you! Trying to figure out if I want to install a dimming mirror or the visor. I don’t want to install the homelink mirror with the internal battery as that is just straight e-waste and I’m not sure if I want to tap into anything right now. Thanks for the info!
TheShark
I like the what you did to get the BS visor to fit. I found that the '20+ Escape visor is actually a better fit, the clip part of the plastic mount is closer to the Mav. I've had one installed for several months now without any issue.
24atlasmaverick
Christopher
Buffalo, NY
Sorry, I know this sounds stupid but you may have just responded to my Facebook poll about this. Do you have photos of the escape one installed? I’m assuming it was a direct swap without issue?
TheShark
Ha, I did respond to your Facebook poll. It was a direct swap. This is the only picture I have, didn't take a before or installation pic so I can't show you the difference in the plastic mount.
I've got a sunroof so it's a bit of a tighter fit side to side but it fits.
Ford Maverick Garage opener Homelink buttons for sun visor? 40A1D0D8-ABDE-4243-84A8-3DB89C8F03D8_1_105_c
I was checking ebay to see if I could find a pic of the mount but no dice. I did run across this visor however:
https://www.ebay.com/itm/3955560847...3D8+sSY2woiM2ggXJS2VBtAXZK|tkp:Bk9SR9KvkPe1ZA
24atlasmaverick
Christopher
Buffalo, NY
https://www.ebay.com/itm/395556084708?fits=Year:2021|Model:Escape|Make:Ford&_nkw=2021+ford+escape+sun+visor+driver&itmmeta=01J6QQ42Z2X6E8TQBC76RYZAT6&hash=item5c18fadbe4:g:i6AAAOSwnHxmXyaU&itmprp=enc:AQAJAAAA4HoV3kP08IDx+KZ9MfhVJKlBiqkjortiLXb5TZPkW1hyKz7cLztMO5eVbUBqd/UBzHJ0ug4lxE2DYyff4+RH3nr+pHuvc5O8ewn8jCzyzD4gCKMBOexx6thCDeBxnh8znLvNXxB/+ABNqyqwU9hnGbEVb4Cnls6nm6bmU7bvuyVlK7SH1gPkLDIEw8nxH4SHQ/kkDGPdlXLTz1Hyc8XK5sYQGRZMhwVPsdorMHPIXYfWuM2VkIkoYYmaAJ8coJ50uDjuR9VE6+z0HUKW1l3D8+sSY2woiM2ggXJS2VBtAXZK|tkp:Bk9SR9KvkPe1ZA
Thank you so much for the photo! And that listing looks like it’s in great shape! New from ford is $300-500 for one visor! I don’t have a sunroof so that should make it a little less tight! For $80 that fits my needs perfectly! And now I’ll have a garage door opener that will always have power! Thank you!
24atlasmaverick
Christopher
Buffalo, NY
Does the escape one extend the pole like the maverick one does for blocking sun on the side?
TheShark
I like it because of the OEM look. I have the homelink visor on my Bronco and I just instinctively start reaching for the visor to open or close the door so I just find it less confusing as well.
24atlasmaverick
Christopher
Buffalo, NY
Is that a photo of it in a Maverick? Only asking because your microphone that’s on the a pillar isn’t there
TheShark
It does but I will say the BS version really extends, my wife has a BS, it's probably overkill for the Mav.
24atlasmaverick
Christopher
Buffalo, NY
Thanks! Is that pic you sent one out of a Maverick?
TheShark
That's a good point, I think that photo may have been from my XLT. When I got the Lariat Tremor I moved it over.
24atlasmaverick
Christopher
Buffalo, NY
That's a good point, I think that photo may have been from my XLT. When I got the Lariat Tremor I move it over.
I have a 24 Xlt no sunroof, my buddy’s 23 sunroof Xlt also had the speaker on the a-pillar like this. One last question, (sorry!), it doesn’t rub the headliner or anything?
Ford Maverick Garage opener Homelink buttons for sun visor? image
24atlasmaverick
Christopher
Buffalo, NY
So I have been looking online, the 2021 model year escape has part number LJ6Z7804105CB, which in ford's parts catalogue goes to a plug-in hybrid model.... the 2020 model year has part number LJ6Z7804105CA (all the same but last letter) and that is for a standard escape, I think? You said on Facebook the 21+ is different?
TNFurb
Kelly
Nashville
I tried finding an escape visor when I did mine but was unsuccessful. That’s why I ended up with the BS visor. I also erroneously thought that there would be a better chance that the BS visor would be identical given they’re built in the same factory 😜
