colinl
Colin
ICT
Oh so the crossover is optional? Might be even better. I was on the fence about the Kicker Key, but I think you convinced me.
Yes the kicker key 200.4 has an integrated DSP that works very well, it's very surprising in this price range.
It sets the gain, speaker size, crossover and time alignment automatically by just playing several test tone files. You don't have as much customization as more costly devices but it also doesn't take a trained tech to install and configure.
fastducky
fastducky
Miata and Titan
I am very happy with the kicker key. The sound is quite impressive.
jcgaskil
Jeff
Allen, Texas
Maverick XLT FX4 (Alto Blue)
I'm considering the same. Did you find the RSE-165 tweeters fit into the OEM location or under the grill or did you have to mount them on top? I am considering the Focal IS Ford 165s for the front since they are plug and play but they are considerably more expensive ($380/pr on Crutchfield).
fastducky
fastducky
Miata and Titan
Tweeters are in stock location , under the grill. I wrapped electrical tape about 6 times around each tweeter. Fit perfectly. Not sure what you mean by plug in play. The door speakers were an exact fit and crutchfield included the correct speaker harness for them.
jcgaskil
Jeff
Allen, Texas
The IS Ford 6.5 speakers are exact replacements with direct connection using the Maverick speaker harness and have the same mounting bracket. The tweeters also match the existing ones so they can drop into the existing slots. It appears they have a higher end tweeter according to Focal but not likely worth the cost difference.
https://www.crutchfield.com/p_091ISFOR65/Focal-Inside-IS-FORD-165.html
Did you reuse the existing mounting bracket in the door? Thank you again for the details on your install.
fastducky
fastducky
Miata and Titan
For the door speakers, crutchfield includes the plastic bracket to mount the speakers.
colinl
Colin
ICT
A local shop has 4 different sets of focal 6.5 components on their demo wall and I listened to them.
The kx2 is really awesome. For 1300 it ought to be. I would use a high powered amp for them, and I can't justify that amp or the speakers but I loved what I heard.
I didn't like the metal tweeter in the Ford IS165. It was really bright to me.
I preferred the auditor rse165 and they're less than half the cost so that helps.
Edit: might as well mention the 4th set I listened to, which were the flax evo ps165. They were pretty smooth. If I'd never heard the kx2 I wouldn't have guessed there was something even better.
WNYEscapee
TJ
BFLO
2023 Maverick, 2019 Cherokee
Thanks for sharing the info on your build. Some of us who are waiting are wondering just how bad the factory system is and what works to upgrade it. You just made it a little easier for many of us in the situation.
jcgaskil
Jeff
Allen, Texas
This is excellent information. I haven't located the Focals locally so wasn't sure. I am so glad I learn from others - saves me $$$. I will add the rse165s as the set I will go with.
Thagh0st
Kyle
Ft worth, TX
xlt maverick
Their alot of sets for the money that are better then focal just giving a heads, definitely listen to them before if you can
fastducky
fastducky
Miata and Titan
I listened to many. I like clear, concise music. Not muddy bass. I found the focals sounded best for $150. Obviously everyone has their own tastes.
fishinmagician
2022 maverick hybrid XL
Does the kicker key need a power line ran to it, or is that taken care of with the Hoel harness?
colinl
Colin
ICT
Needs power and ground. I think the amp can use as small as 12ga.. but if I'm pulling a power wire I'm at least bringing in 8 gauge to future proof it a bit.
fastducky
fastducky
Miata and Titan
That was an option on Hoel. I decided to not buy the extra wiring kit. I ran a wire from battery to the hoel harness. He included a power and ground pig tail to make wiring the power and ground much easier. Message Hoel, he is very good at responding. I am just cheap and decided to run my own power and ground
PCK
Phil
VW R32; Maverick Tremor
I did not use the crossovers. After lots of research I decided not to use them . Apparently the kicker key does a good job of balancing the sound.
To clarify, you did not use the 12 db high-pass passive crossovers that came with the Focal set but used the Kicker Key in bi-amp mode so that it used the 24db at 3500 Hz active crossovers, correct?
But in bi-amp mode, you only powered the front door speakers and tweeters with the Kicker Key amp, also correct?
