FORSCAN first time connecting
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
Received the OBDLinkEX and hooked up to the Maverick.
Ford Maverick FORSCAN first time connecting ERRORcodes
Looks like FORScan found a few yellow triangles.
How do I clear these or do I have to take to the dealer to have cleared?
Would like to change a few things in FORScan that have become annoying.
>Hyperflash on turn signal since I have LEDs installed.
>Turn the AirCondition OFF when starting the Maverick.
..... Every time the Maverick is started, the A/C comes on.
..... Do not need the A/C to come on when weather is warm & windows are down.
..... The fan is on all the time blowing air toward the floor.
>Would like to turn the chime off when the engine is running & door is opened.
And to be able to change other things as they are found out about.
Any help will be appreciated.
Thanks
Tbone289
You can clear the DTCs in the DTC section on the left (DTC in yellow triangle).
I can't help you right now with the configurations you want because I don't have the 2025+ reference, but if you don't get help with that from other members, I can try to help you. There are plenty of FORScan guides out there for you to refer to on how to operate the software. Also, one of the first things you need to do is find the 2025+ configurations spreadsheet and see which items on your list can be altered.
rugedraw
Javier
Miami, FL
2021 Ford F150; 2023 Bronco Sport Badlands; 1991 Mustang 5.0 coupe.
You can clear the codes by clicking the yellow triangle that says DTC on the left, but keep in mind that codes are not problems......only problems are problems. When the codes end with a 8 in the status byte, it means it is a stored code and not an active fault. See example below from my truck:
Ford Maverick FORSCAN first time connecting 1784143236710-kk
As far as the things you want to do: Not sure if there is a way to not have the a/c turn on automatically. You'd have to dig through the HVAC module spreadsheet to see if something stands out that corrolates with that effect.
pc4mike
Kentucky
2025 Ford Maverick
Thanks
The AC coming on automatically is annoying. What I do is, every time I use climate controls I shut fan off before shutting engine off. That way AC or heater doesn't come on automatically.
Getting accustomed to screen controls for climate control is one of the problems I have with the system. My older vehicles have screen controls for the entertainment system yet I still have buttons and knobs for climate control and I always turn off AC or heater when shutting motor off. Personal preference. Yet in these Mavericks it's necessary.
Puppa3
Mario
Deptford, NJ
Maverick Lariat
Just a thought put what u want to change into Chat GPT and should walk you through step by step
AlpineKid74
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
Found a configurations spreadsheet for the 2022-2024 Ford Maverick Forscan Coding List By EONR24 that is posted by @lavaspill back on 18 Sep 2025. (https://www.mavericktruckclub.com/forum/threads/current-forscan-spreadsheet-for-2025-maverick.73047/) Under Functions there is a the line Engine Sound Enhancement Disable (2025 only). Wondering if this spreadsheet is for the 2025.
Reading through spreadsheet, it looks like it is.
Have found the Functions that need to be changed. These are three of eight at least.
Door Ajar Chimes Disable IPC* 720-01-02 xx0x xx-- WORKING
All 12v Power Outlets Adjust Cutoff Time BCM (EZ) "Power Point Timeout Enable", Adjust "Power Point Timeout s" Timeout is calculated in seconds, Factory is 4500s = 1hr15min 5 minutes = 300 seconds
Headlight Switch/Dial Default to "Last Known Position" instead of "Auto" BCM* 726-27-05 1xxx xxxx xx-- Factory coding is "0" WORKING
How does one know what the original 'code' is for any of the Functions?
In the videos it is advised, that each module should be backup each. That I will do the next day after this smoke moves out. Air bad for breathing in Northern Michigan right now.
What is 'Engine Sound Enhancement Disable (2025 only)'?
Thank you for the help.
Have found the Functions that need to be changed. These are three of eight at least.....
😱 Wow
Ford Maverick FORSCAN first time connecting Screenshot_2026-07-16-13-19-32-10_40deb401b9ffe8e1df2f1cc5ba480b12
Tbone289
Yes, I would assume that it is for the 2025 since the http link specifically says current-forscan-spreadsheet-for-2025-maverick. :wink:
You don't need to know what the original code is as long as you back up the "as-built" configurations for all of the modules before you start changing code. Keep the backups safe and you can always restore to the factory configuration from them. Then, once you modify code, you can make "as-modifed" backups for the modules you change as well so that you can re-load the modified code at any time.
This disables the sound engine sound enhancement that plays through the speakers on some Maverick models such as the Tremor and Lobo.
You're welcome! (y)
AlpineKid74
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
Thank you
Will look into this and find out if this will work & work for me.
