Using ForScan for first time, bunch of DTC's!!!
jasperpants
Jason
Northern Virginia
Prius
Just received my OBDLink EX FORScan ODB Adapter and installed the latest FORScan release.
Hopped in my Maverick all excited to see what the software will expose and discovered a few errors! They haven't tripped the check engine light(yet!). Any one had any of these before? B14A7 seems pretty serious
Here they are:
Code: B14A7 - Puddle/Cargo Switch Input
Additional Fault Symptom:
- Circuit Short To Ground
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Body Control Module
Code: B1A01 - Speaker #1
- General Electrical Failure
Status:
Module: Audio Control Module
Freeze Frame #1:
-EVENT_TIME: 2773373 s (Mon Dec 13 20:31:48 2021) - Event time
-TOTAL_DISTANCE: 285 km - Total Distance
-ELEC_POE_STAS: Not Received - Electric Power Status
-ING_STAS: Run - Ignition Status
-POW_TOR_STAS: Powerpack On Torque Available - Powerpack Torque Status
Code: B108E - Display
- Circuit/Component Protection Time-Out
Status:
- DTC Maturing - Intermittent at Time of Request
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 4037591 s (Tue Dec 28 11:42:06 2021) - Event time
-TOTAL_DISTANCE: 555 km - Total Distance
Any recommendations on what I should do next? Wait, take it in to the dealer?
Maverick2022XL
name
hinterlands
Reset the codes and see which ones come back.
This probably will unless it is something intermittent.
Puddle lights usually are on the mirror if equipped though it could also be referring to the bed light on the back of cab. That will need to be traced out using volt meter and wiring diagram to find where the problem is along the circuit.
I'd have the dealer fix that since that is most likely the fault of the factory when it was assembled. Just don't tell the dealer you used Forscan but some regular OBD2 reader or pulled it from the instrument cluster when you bring it in.
Maverick_Innovation_Designs
California, CA
'09 F-150, '22 Maverick
Puddle lamp ground fault also showing. With the XL, there definitely aren't any puddle lamps so I'm curious what it's referring to.
