Sad_Mav
Ken
Massachusetts
2025 Maverick XL AWD
I used Forscan to disable Auto/Stop Start on my 2025 Maverick.
I'm Mircrosoft Certified Professional, HP Expert and an A+ Certified PC tech. I'm also a bit OCD so I tried to take detailed notes.
Here's a copy of my notes; I can't say they are perfect but I believe they should be helpful.
Download and install Forscan for Windows on your laptop.
Obtain a FREE Forscan license *2 month Trial
Connect OBDLinkEX to OBD port under driver’s side dash then connect it to laptop
*OBDLinkEX LED should be Green
Open FORScan on PC
Turn Ignition ON. *NOT Start
Click ā€˜Connect to Vehicle’ icon on FORScan. *A Warning pop-up will appear, click OK
FORScan will show a list of Saved Vehicles or start a scan for a new vehicle
At end of scan will be prompted to ā€˜Save Vehicle’ if new
Click on ā€˜Configuration & Programming’ icon, below the Wrench icon.
FORScan will show ALL modules in both ā€˜AS BUILT’ MODE and ā€˜EASY’ MODE
Go to PSCM [Power Steering Control Module] > AS BUILT > ā€˜Run Service Procedure’ *Warning Pop-Up
FORScan will display all PSCM modules in hexadecimal format *Don’t change anything!
At bottom of screen choose: SAVE ALL > .abt file > Destination > Save > then STOP SERVICE PROCEDURE
*You now have a back-up of all original default settings in the PSCM modules if it needs to be restored.
Leave ā€˜As Built’ mode and go to ā€˜Easy Mode’ by clicking the ā€˜Configuration & Program’ TAB
Click the Easy Mode ā€˜PSCM' module > Run Service
Scroll and find the Auto Stop/Start entry
Should be 3 Choices Disable | Enabled with Angle Inhibitor | Enabled without Angle Inhibitor
Select DISABLE then click on the Checkmark
Will now show as DISABLED but must click on the WRITE button to complete configuration!!!
A pop-up will appear when you click on WRITE to confirm your choice, click Checkmark to confirm
Pop-Up should appear after writing:
ā€˜BLOCK PROGRAMMED SUCCESSFULLY’
ā€˜Please cycle ignition OFF then back ON’
… DON’T click OK on the Pop Up yet!
Cycle ignition OFF then back ON then click OK
Programming is now completed.
Click the ā€˜STOP SERVICE PROCEDURE’ icon. *Square Stop icon
DONE
Confirm that everything is working as it should.
Auto Stop/Start should be OFF and STAY off without pushing button. :clap:
Wow 😲
Will that disarm all the nukes too??
Thank you for posting.šŸ¤
I do not foresee FORScan in my future.
Carlitos_92
Outforawalk
Hurricane UT
Velocity Blue 2025 Ford Maverick XL Hybrid Setup for towing behind MH
Can this forscan thing turn off the auto lock feature at 12 miles per hour I have a 2025 hybid XL
Maverick77
Randy
Dodgeville Wis.
2026 Maverick Lariat
Thanks for the info. Wish GM has something similar to Forscan. I used Forscan several times on my previous F-150 to disable annoying TPMS bogus warnings, and disabled daytime running lights that used the low beams.
Red Pepper Maverick
Robert
Louisville, KY
2025 Maverick Tremor
`I had a 2019 Ford Ranger that I owned for 5 years. The whole time I had it I kept a night light plugged into the AC plug in the passenger area. With the light plugged in the S/S was disabled for the entire time I owned it. I now have a 2025 Maverick and I do the same with the night light plugged into the AC outlet in the passenger area. That keeps S/S disabled as well. I've unplugged the light and the S/S will shut the engine off at stop lights. The night light thing has worked for me on two vehicles. The only explanation I have is the computers see a drain on the AC system with the night light and prevent it from shutting the engine off. You need to put tape over the sensor on the light so it will always be lite when the engine is running. Night lights are fairly cheap, other methods not so much.
Meagdog
Andrew
Kansas city
2024 maverick lariat fx4
Open FORScan on PC
DONE
This is a great post for those of us that were apprehensive to try it. Appreciate it.
Sad_Mav
Ken
Massachusetts
Really? That's great!! I assume you mean the 'Cigarette Lighter' accessory plug? I would like to hear from others to see if this works for them as well.
Red Pepper Maverick
Robert
Louisville, KY
I should have been more specific. Behind the rear console in the rear passenger area on some Mavericks is an AC outlet like you would find in your home. There is a 400 watt inverter that supplies 120V AC. You can plug things like an electric razor, toothbrush or other low wattage appliances into. I think it is an option so may not be on all Mavericks. My Tremor also has one in the bed area near the tailgate on the left side. The night light would be like one you would plug into a wall outlet in your home. I got mine off Amazon, but I assume you could get them at Walmart or Target.
Ford Maverick Forscan | Disable Auto Stop/Start | Step-By-Step DIY Instructions (on 2025 Maverick) Screenshot 2026-04-13 at 1.43.39 PM
