FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL
Iakona
Jason
Elgin, North Dakota
2023 Maverick Tremor
I may test it out once and let you know! The launch control can be enabled on any MAVERICK! but the little display and button for it can only be enabled on the 4 inch cluster.
Gotcha. I may play around and see if I can figure it out on the larger display....
Dueces
So, I finally got around to screwing with Forscan, and I added the launch control stuff, but it appears that it won't work on our trucks. Were there other parameters that need to be met, or are we just SOL?
Any chance you have looked into this further?
EONR24
EONR24
Swag
United States
2024 Ford Maverick XL
From my testing, the launch control function on the 4 inch cluster is purely aesthetic. It does not activate any type of mechanical launch control, just the visual button and color filling MPH in the Cluster.
But, Say you got a tune with launch control activated by the tuner. You could then enable the launch control and the ford performance myview in Forscan to display it accurately on the cluster.
I turned launch control off for now and just have the ford performance MyView on without the launch control button.
xxgeterdone
Problem Chiled
Indiana
22 Maverick
Hey everyone!
I just found a coding to enable the Ford Performance MYVIEW digital speedo on the 4 inch instrument cluster. I also found a coding to make it your default MYVIEW screen so you don't have to keep switching back to it every time you go for a drive. THIS CODING ONLY WORKS ON THE SMALLER 4 INCH CLUSTER!
MAKE FORD PERFORMANCE MYVIEW DEFAULT
1. Open IPC AS BUILT
2. Go to 720-17-02
3. Replace the second digit with a "5" as shown here
x5xx-xxxx
4. Write the changes and let Forscan correct the checksum
ENABLE FORD PERFORMANCE MYVIEW (Only 4 inch Cluster)
2. Go to 720-17-01
3. Replace the tenth digit with a "6" as shown here
xxxx-xxxx-x6xx
Here are some pictures of this screen and a picture of my original coding compared to the new coding!
UPDATE: Just added LAUNCH CONTROL and set launch control limiter to 3000rpm! As you rev the engine with Launch Control on, the MPH fills up with red the closer you get to 3000rpms. I will likely not use the launch control as I do not want to damage anything prematurely! Just wanted to see what the coding would do! Check out the coding and pictures below!I
ENABLE LAUNCH CONTROL BUTTON IN DRIVER ASSIST (Works on 4 inch CLUSTER only!)
1. Open IPC Easy Mode
2. Enable "Launch Control"
ENABLE LAUNCH CONTROL BUTTON AND ADJUST LIMITER
(only 4 inch CLUSTER screens)
2. 720-17-02
3. Replace the first digit with a digit based off of the diagram below and in the pictures. I replaced it with a "6" for a 3000rpm LC limit for example.
6xxx-xxxx
Launch Control Counter Limiter
0= LCCL OFF
1= LCCL 2500rpm
2= LCCL 2600rpm
3= LCCL 2700rpm
4= LCCL 2800rpm
5= LCCL 2900rpm
6= LCCL 3000rpm
7= LCCL 3100rpm
8= LCCL 3200rpm
9= LCCL 3300rpm
A= LCCL 3400rpm
B= LCCL 3500rpm
C= LCCL 3600rpm
D= LCCL 3700rpm
E= LCCL 3800rpm
F= LCCL 3900rpm
So I’ve done the coding and for some reason i get the ford performance speedometer and thats it no launch control button i also enabled it in the ipc ez ad as whell has anyone tried the launch control to c if it works??
