Forscan and second battery for longer stops ?
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
Hi guys, recently I read the news that finally you can disable the auto stop and start with forscan.
On my case I'm on the opposite side, I would love to maximize it, my daily comutes are 80-90% of trafic jams red light to red light trafic, matter of fact I rode less than 4 2 hours ride on my truck since new (about a year), I like the auto start and stop a lot, my complaint is because the bms sometimes decide I have no power enough or the AC etc it doesn't shutdown the engine.
Could I install a 2nd battery, and with forscan help the system to shutdown more often and stay longer on that mode while I'm stranded on traffic?
Thanks a lot in advance to the forscan community , and congrats to those that finally have the option to have your truck your way by disabling those features that you don't like, while enabling those that you want like the TSR etc.
Stimpy433
Chad
Iowa
2022 Mavrick
Yeah, you need a hybrid instead of the ecoboost.
Devu
Caribean
I know, I know. When my two cars decided to die in the middle of the pandemic none hybrid was available on my area, matter of fact hybrids just hit the area few months ago, but I was in a hurry so i got the EB, I freaking love the power of mine but would love the hybrid too.
So with the hybrid out of picture for now, there's anything that can be done for my 2.0 EB ?
SFB
Daniel
Fullerton California
2019 Ranger Crew Sport XLT
Where would you even put a second battery?
My42waffles
Kegan
21 f150 powerboost lariat 20 fusion titanium hybri
With the way the system works having a second battery would be of no benefit since battery charge is only 1 of many factors in start/stop. interior temp and engine temp play a bigger part in start/stop than battery charge.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
I think I could put on the same place than the hybrid, below the rear seat ?
You would have to get a vented battery, and run a tube from the vent to outside, to have it in the passenger compartment. That's how the hybrid's 12v is setup, otherwise it would not be safe to have a 12v lead acid battery inside.
The other issue is the charging system is not designed to charge two batteries.
Devu
Caribean
Roger that. Thanks, didn't think on the battery ventilation.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
You need a dual battery isolator kit:
DEWINNER 12V 140Amp Dual Battery Isolator Kit Manual/Auto Modes VSR-Voltage Sensitive Relay Kit, with LED Screen, Voltage Display, Designed for ATV, UTV, Boat, RV, Camper 5 Wheel Off-Road Vehicle https://a.co/d/4iyBHXs
- 2-4 gauge wire
- battery box mounting solution in the bed.
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
A 2nd battery would not help this issue. The Hybrid has an electric motor driven AC compressor. The EB has a ICE driven AC compressor.
Devu
Caribean
- 2-4 gauge wire
Do you think it could help or I missing my plane here ?
Devu
Caribean
Hi. I'm not looking to run the A.C, I know only the fan runs with the battery, I just want the engine to stay off for 2-3 minutes while I wait on the traffic lights and be ready once is my turn to go.
volksnuts
Katy,TX
Maverick Lariat HPR
Your traffic lights are 2-3 minutes long?
What actual benefit are you looking for here? Extended gas mileage?
I’m not really understanding the thought here
Devu
Caribean
I just want the engine off as much as possible, yes for better mileage, I also stay put for 1/2+ hour at the truck, so having the battery voltage at good levels would help me on the traffic lights too.
volksnuts
Katy,TX
Maverick Lariat HPR
What you are proposing to going to only give you a very marginal improvement and probably not worth the hassle.
Maybe just turn the truck off if you are sitting long enough to make a difference
Direct injection engines are EXTREMELY efficient in an idle situation (also why they are able to start so quickly)
Probably more effective if you were to hypermile when moving vs having the engine off
