Forscan and warranty question
  • Thread starter Deleted User 24227
  • Start date
  • Watchers 3
Deleted User 24227
Guest
Am I correct to assume use of a forscan to make changes would void my warranty? I don't have it but before considering it I want to know if my assumption is right?
Equator Guy
Topsham, ME
2023 Maverick XL., 2015 Rav4. 2012 Suzuki Equator
I don't think there is a simple answer. If you make changes to the sound system and later have a transmission issue, they would be hard pressed to deny your claim. However, you mess something up while using Forscan, you can't assume the dealer will fix it for free under warranty. I have made changes to the audio system to accommodate different speakers and amp, as well as disabled auto-stop-start. Very happy with the changes, and have no plans to make more.
Deleted User 24227
Guest
thank you, I'm not looking to do anything radical, maybe try to access the posted speed on my display
Goldie
Richard
Franklin,Pa
Mavrick XLT 2022
where do you go in forscan to turn off the auto stop ?
Carlitos_92
Cancunbadlands
Cancun
Cancun
The short answer is: Not automatically, but it’s a bit of a "proceed with caution" situation.
In the United States, the Magnuson-Moss Warranty Act protects consumers. By law, a dealership cannot void your entire warranty just because you used FORScan. However, they can deny a specific warranty claim if they can prove that the changes you made directly caused a failure.
Cancunbadlands
Cancun
Cancun
A dealer can’t refuse to fix a leaky sunroof because you used FORScan to enable "Bambi Mode" (keeping fog lights on with high beams). Those systems aren't related. However, if you mess with the Power Control Module (PCM) settings and your engine develops an issue, they could argue your modifications caused the stress that led to the failure.
Deleted User 24227
Guest
great information, thank you 🙏
