Ford tire size configuration / recalibration for larger tires?
ATL_Mav
Logan
Atlanta
Kawasaki zx6r, bmw 328is
I am running 245/65-17's. If Waze is accurate, my speedo does not get off 1 MPH until I reach 55 MPH. Where my actual speed is 56 MPH. Even at 78-80 MPH it hasn't reached 2 MPH off. Still just 1 MPH. Pretty much a non issue at that tire size and not worth taking action.
Thanks
Atisko
Branford ct
Nissan rogue
Interesting,could you measure the diameter of your tire?
ATL_Mav
Logan
Atlanta
I was going to leave it alone but a guy at my work has forscan so we changed it. Did a short test drive on the highway and speedometer is perfect now.
  • Like
Reactions: Aza
SoCal OG
Wait..so it can be changed using Forscan?
ATL_Mav
Logan
Atlanta
Well I take it back for the moment, we changed it in the bcm, test drove and it was good. Went to go home and it had an awd fault. A code in the pcm saying it was getting incorrect information from the bcm. So we'll have to check tomorrow and see if something else needs to be changed as well.
ATL_Mav
Logan
Atlanta
I haven't been able to change it in forscan without it saying awd fault and showing codes in the awd, pcm and pscm. So for now it's back to original settings. I will try again when I get time.
vezpa
EMG
IL/IN border
Too many to list.
If your truck came with 225 65 17 tires and you put 245 65 17 tires on (like I did) it will be off 2mph at an indicated 55mph.
Ford Maverick Ford tire size configuration / recalibration for larger tires? Screenshot_20220125-060911_Firefox
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
2022 Ford Maverick Lariat
But according to two GPS apps and some radar signs, it's off 1 MPH. Not that 1 MPH is a big difference. Just reporting what I'm observing.
Naranjita
NAH-RON-EE-TAH
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
That assumes the speedo is correct in the first place, and it probably isn't.
Naranjita
NAH-RON-EE-TAH
Good point. And it's possible the speedo was set by Ford based on the 235/65-17 for the FX4 models. THat would make it 1 MPH off going to 245's. But either way, my speedo is not off with MAXXIS RAZR AT 245's until I get to 50 MPH, when it finally gets to 1 MPH. And it still is not 2 MPH off even at 80 MPH.
jspa
Jeremy
Cumming, GA
Hyundia, Santa Fe Sport
Were you able to mess around with this any more? I am trying to adjust mine using forscan and I am getting AWD errors (DTC codes) for any value I input with the exception of the original number. I am interested to see if there are any workarounds to not get these errors and fix the speedo.
Thanks!
Chris_G
NOVA
C-6 Corvette
Thanks!
Don't the other modules need to be forced to learn new input 🤔
SkeeterB
The Woodlands, TX
Stock 225/65 17s and speedo is 1 mph too slow. Driving at 1 mph over speed limit bothe Maps and Waze indicate I am at posted limit.
