FERALMAVERICK
FERALMAVERICK
Brent
2025 maverick tremor
Caps off pleasešŸ˜‰
sorry , i have the mavericktruckclub open on my work computer in the back round for down time , and we use caps for everything and i forget to cap lock off lol
Platinum2
MI
Ford
I didn't realize the radiator and intercooler are smaller on the Tremor than standard EB Mavericks. The intercooler I have on my truck is 240% larger than stock. Sounds like it wouldn't fit on the Tremor. šŸ¤”
FERALMAVERICK
FERALMAVERICK
Brent
[/QUOTi beleve
i believe the radiator size is the same the intercooler mounting it just different on it , but the cooler is definitely smaller and a different configuration , the driver upper bracket/hanger doesn't line up at all with the new cooler and it seen to be recessed for clearance
what cooler do u have? cvf ?
F150 2.7 TT user
Kenneth
SE WI
2017 F150 XL 2.7, 2016 Edge Sport
I threw out the factory Intercooler the third day after buying my Maverick. A good upgrade to minimize the likelihood of timing being pulled due to high intake temps.
I use a modified and tuned 2.7 with a CVF inter-cooler. The IAT2 temp that is critical is 115-1120 degrees F. Is this the same for the 2.0 EB?
Platinum2
MI
Ford
FERALMAVERICK
FERALMAVERICK
Brent
Platinum2
MI
Ford
I looked and inquired about it also ( looked like a nice piece ) but sadly same issue with the cvf honest really fit behind a tremor lower with out cutting away the bumper.
That's actually my truck (the Carbonized Charcoal Metallic) in the product photos.
Maverick2022XL
name
hinterlands
Nice. I've been considering adding one of these myself. I am not into performance modding but this looks to be a good upgrade to prolong the life of the turbocharger. Without a tune will this improve the responsiveness of the acceleration in normal drive mode?
F150 2.7 TT user
Kenneth
SE WI
An inter-cooler does its job after the turbocharger so it will not affect the turbo at all. The reason for larger ICs is to keep intake temperature below the point spark timing is retarded to stop knock. The small volume inefficient stock IC can become heat-soaked quickly ad drive up intake temperatures. Aftermarket ICs delay or eliminate the heat-soak issue. On my 2.7 the threshold temperature where the ECU begins to retard the spark is 115 degrees IAT2. My old stock IC went higher regularly my CVF Titan has never passed 115 degrees except when idling.
Maverick2022XL
name
hinterlands
Thanks, I was under impression it cooled the air on the intake side of the turbocharger not outtake. It still looks to be useful without a tune for towing.
FERALMAVERICK
FERALMAVERICK
Brent
It absolutely does all of that that. There is definitely a change when @ speed or accelerating . I finally got to go out and play a little after installing this week. Just driving as normal ive picked up .3 mpg so far and it's definitely more responsive when u step into it at speed (no its not put you in the seat power increase) I would guesstimate 8-15 whp
Automan21
Mel
ā€˜23 XLT Eco AWD 4K Tow
Just picked up the ford performance IC with a discount code and free shipping for $760.
figured I’d do this one since it’s a Ford product and not an aftermarket so they can’t bitch when it comes to warranty work.
FERALMAVERICK
FERALMAVERICK
Brent
That's exactly what I did, bought it directly from ford discount code cashed out some ford points . Lol
Maverick2022XL
name
hinterlands
Same here. Been on the fence about it for awhile now but @FERALMAVERICK unintentional enabling and the sale pushed me off it. $250 discount is a shit or get off the pot decision. Next up to look into a Monte GT or GTR tuner. Their stuff looks to cater more towards daily driving than high performance racing. More research is needed before purchasing.
