GLOBAL WINDOWS CLOSE ON FORD MAVERICK TREMOR 2025
A420QT
Marcelo
Argentina
Ford Maverick Tremor 2025
Hi there, can anyone help me set the Global Windows Close/Open on my Maverick Tremor 2025 with Forscan?
I have set Global Windows Close/Open to Enable but nothing happens. I believe something else needs to be done. I have read some guidelines regarding other Maverick older models, but I would like guidelines for this model.
Will this setting also close the roof?
I really appreciate any help you can provide.
MTAlmeida
Marcelo
Belo Horizonte, MG, Brazil
2025 Ford Maverick Tremor
I know it can be done... did on my ... one push OR 3s push to close...
don't have the exact lines to change (did with a specialist)
will try to find the lines later on
A420QT
Marcelo
Argentina
I appreciate it.
A420QT
Marcelo
Argentina
Hi bro, don't bother. I figured it out. It already works on my Tremor 2025. Thank you again.
Cancunbadlands
Cancun
Cancun
A420QT
Marcelo
Argentina
I found the answer on this forum. Please read carefully and pay attention to the * reference regarding modules. It is very important for this to work. When you see a module, like PPM but with the *, PPM*, this is to say you need to modify the As Built Format module. Follow the instructions and you are set to go. You need a scanner with HS/MS protocol for Forscan, Forscan software that you can download from www.forscan.org AND generate a free two months trial full license, because otherwise you won't be able to modify any module. Good Luck.
